Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-26-2020, 07:08 PM   #1
Steve Cole
What is this "connector" actually called?
Anyone know what this is called and where to buy one? Thanks.
Steve Cole is offline   Reply With Quote
Old 10-26-2020, 09:17 PM   #2
dmjlambert
dmjlambert's Avatar
Re: What is this "connector" actually called?
GM 12191376 Battery Positive Cable Junction Block. Looks pretty nifty. For recent model years. You can google for it and find a bunch of different sources to buy from. https://www.google.com/search?q=GM+1...junction+block
I don't know about a source for the weird L-shaped terminal that crimps onto the cable.
Old 10-26-2020, 11:27 PM   #3
Greasey Harley
Greasey Harley's Avatar
https://www.amazon.com/Genuine-GM-12.../dp/B000QIQUE6
https://www.ebay.com/itm/25363518264...gaApXiEALw_wcB
Doesn't come with the connector. looks to be some kind of "flag terminal" , Maybe it has a GM part number and could be sourced from the stealership?
Standard flag terminal looks like it would probably work fine.
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 10-27-2020, 08:32 AM   #4
Steve Cole
[QUOTE=dmjlambert;
I don't know about a source for the weird L-shaped terminal that crimps onto the cable.[/QUOTE]
Thanks, but that L shaped terminal is the part I need, not the box. I am just looking to join the wire from the alternator to the positive battery cable for my LS swap. I will look into the flag terminal that Greasey Harley mentioned.
Thanks.
Old 10-27-2020, 09:36 AM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What is this "connector" actually called?
Why not use this. It looks pretty close to the same thing just run them straigt out.
https://www.summitracing.com/parts/c...kaAlFjEALw_wcB
https://www.summitracing.com/parts/s...gaAlkrEALw_wcB
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-28-2020, 01:15 AM   #6
chev-obsession
chev-obsession's Avatar
Thanks.
You might be able to find the flag terminal through your GM parts dealer or if you have an automotive repair shop that specializes in electrical stuff, they may have that terminal. It’s to connect the fusible link to the positive cable which you know.
If you can’t find the flag terminal, I have an extra cable with the fitting you need that needs a new end crimped on... you can have it if you’d like it.
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 10-28-2020, 08:44 AM   #7
Steve Cole
That is a very kind gesture, and very much appreciated ! I actually have the full cable I removed from the donor truck but I am not using it. I went with some custom made cables and I am trying to stick with those. I was going to "tie in" my alternator wire to my positive cable with one of those flag terminal connectors if I could find one. My positive cable actually has a 6 " lead coming off the end of it at the post connector so I may just crimp the alternator wire to that and be done with it.
Thanks for your reply!
Old 10-28-2020, 12:41 PM   #8
chev-obsession
No problem and good luck!
1965 c/10 swb
1969 c/10 lwb
Old 11-26-2020, 07:29 PM   #9
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
https://ceautoelectricsupply.com/ind...style-eyelets/
unfortunately shows out of stock... but maybe more searching using some of those key words will help you find it
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
