Old 07-07-2002, 07:08 PM   #1
KP1972
KP1972's Avatar
Question chrome oil pan
When I bought my truck I was given as a "truck warming present" a chrome oil pan. I have been told by some that they never seal well. Is that your experience or can I go with it? My current "painted" oil pan has a hairline crack in it and it needs replacing. If I can go with the chrome then do you have any special instructions to make it work well?
Thanks always for your advice!
1972 Chevy Custom/10
www.PictureTrail.com/KP1972
Metroplex Muscle Car Club
www.PictureTrail.com/DreamCarArt
KP1972 is offline   Reply With Quote
Old 07-07-2002, 07:33 PM   #2
jlmtrout
Make sure the pan is for your year series block. I went through 3 before I found the correct one. The difference is in the curves around the bottom of the timing cover and the back of the block. There can be as much as 1" difference depending on the block/pan, with the rails sitting flush on the block. Also, consider a 1 piece rubber gasket, they have steel inserts so you can't over tighten and warp the rails and they won't leak as there are no seams when the gasket surface makes a corner. Added bonus, they are reuseable. Good luck and keep on truckin'!---Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed
Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake
600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash
jlmtrout is offline   Reply With Quote
Old 07-07-2002, 09:24 PM   #3
racedvl
racedvl's Avatar
I am not proud to say I have a chrome pan. But I needed one and it was free!! Anyways, chrome usally never seal that great, and it does not dissapate heat that good either. But i will say that I am using a Fel-Pro one peice pan and it's been there for 2 years or so, and I have not has any leaks. If ya can't tell, I'm not a fan of chrome....
racedvl is offline   Reply With Quote
Old 07-07-2002, 09:38 PM   #4
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Sand the area where the gasket goes with 180 grit or so. The chrome is so smooth that they don't like to seal. The only thing I don't like about chrome is that it will rust down there.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
