Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 08-02-2020, 07:20 PM   #1
4u2nv
Sticky Starter
I go out to start the c10 today , starts up as usual and the starter sticks , talk about having to think quick when your not use to that , on my way out of the cab I pop the hood and run to the garage as it's still rolling over , grab a couple wrenches to disconnect the battery and as soon as I get back and get the wrench on it , it stops , It was rolling for a while , I could smell it.
So now I'm thinking every time I start it it's going to stick again. JEEEZ.
4u2nv is offline   Reply With Quote
Old 08-02-2020, 08:06 PM   #2
blazer2007
Re: Sticky Starter
Ign. switch on the column maybe,just a quick suggestion.. Mine is a 78 model
blazer2007 is offline   Reply With Quote
Old 08-03-2020, 11:17 AM   #3
Axle
Axle's Avatar
Re: Sticky Starter
Or a bad solenoid. Clip a voltmeter onto the 's' terminal (the little one) of the starter and put the meter in the cab. If its the ignition sticking you'll see voltage on that terminal after you release the key.
Axle is offline   Reply With Quote
