06-07-2011, 11:17 PM | #76 |
Re: Some guys have skills and some have bills
What about the radiator. Look into the aluminum one. Let me know if you need a hand. That truck is gonna run great.
06-08-2011, 03:28 PM | #77 |
DUDE!!!! Do you have manual.. ? if its not your daily driver.. most ofthe fun is in fixing it yourself bro..
06-08-2011, 09:38 PM | #78 | |
And for me it's been fun learning in the engine build, but I must admit the fun for me is definitely in DRIVING HER! Before the tear down and rebuild of the engine she was my daily driver for the past 7 months =) Posted via Mobile Device
Thank you god for all your blessings! My mini build (I had a great starting point) http://67-72chevytrucks.com/vboard/s...d.php?t=440743 Last edited by Bull72; 06-16-2011 at 05:59 PM. |
06-08-2011, 09:39 PM | #79 | |
Thank you god for all your blessings! My mini build (I had a great starting point) http://67-72chevytrucks.com/vboard/s...d.php?t=440743 |
06-12-2011, 02:13 AM | #80 |
Got the engine back from the machine shop they couldn't do anything for my crankcase because it was already ground down too much. But they had another one that they cut .10 and the block is .60 also went with the flat top pistons.
pics attached
Thank you god for all your blessings! My mini build (I had a great starting point) http://67-72chevytrucks.com/vboard/s...d.php?t=440743 Last edited by Bull72; 06-12-2011 at 02:25 AM. |
06-12-2011, 02:45 AM | #81 |
So these aluminum heads were originally going to be put on a race truck. So they were ported out quite a bit and the valves were heavy duty and meant to handle Nitrous if needed. No... I'm not planning on nitrous, that's just what he was going to do before he sold the heads to me. Here is the Melling oil pump bolted down as well.
06-12-2011, 02:55 AM | #82 |
Put the color of choice on - bright orange, you should be able to see this engine even in the dark baby
06-12-2011, 03:24 AM | #83 |
We put on the heads and were stopped suddenly when we realized that the new Cam I received was broke in half dangit!!! It sure did slow things down a bit. We stopped there and I have to send it back to Jegs. On the other hand I was thoroughly impressed with Jegs customer service. They said they would send me prepaid shipping tags on Monday and and I would not have to pay for the return shipping as well.
My buddy said it would be a good idea to get some new pushrods http://www.jegs.com/i/Proform/778/66890C/10002/-1 , a lock plate kit http://www.jegs.com/i/JEGS+Performan...20305/10002/-1 , and cam button http://www.jegs.com/i/JEGS+Performan...20390/10002/-1 as well. So these are on the way. Here are my shop cleaned oil pan and timing chain cover. We are going to paint them, but we did a quick mockup of the timing chain cover with a gray color my buddy had lying around and the edelbrock performer manifold. I'm still deciding whether I should paint the oil pan and timing chain cover orange like the block, use the gray finish in the mockup, or go with some chrome... Any thoughts????
06-13-2011, 10:44 PM | #84 |
I like the gray, but to be honest have never been fond of chrome on timing chain covers.
Posted via Mobile Device |
06-14-2011, 07:28 AM | #85 |
Rollin in my K5 toaster
Nice build...I love the smell of RTV and paint curing on a new engine.
edit:That big A$$ fan I see you have will be handy when you break in that cam. I could use a fan that big. Last edited by Torrey72; 06-14-2011 at 07:33 AM. |
06-14-2011, 07:16 PM | #86 |
the port work on that head sure looks rough...
06-15-2011, 11:19 AM | #87 |
I wouldn't have any frame of reference to be honest =) My buddy did the work himself and he said he took away some of the restriction areas and should flow much better this way.
06-15-2011, 02:51 PM | #88 | |
As for the manifold, have to change it up and return the Endurashine performer to Jegs. After closer inspection it was just a bit too small for the heads. If you see the "mockup" picture above you can almost see the ports peaking out. So I will be ordering a Professional Products Hurricane Manifold from Summit http://www.summitracing.com/parts/PFS-52030/?rtype=10 Also, decided on a real nice silver/gray for the oil pan. pic attached:
Thank you god for all your blessings! My mini build (I had a great starting point) http://67-72chevytrucks.com/vboard/s...d.php?t=440743 Last edited by Bull72; 06-15-2011 at 11:52 PM. |
06-24-2011, 09:25 AM | #89 |
getting closer....
06-25-2011, 07:44 PM | #90 |
More pics, ordered some Felpro oil pan gaskets, rocker arm studs, & adjusting nuts, so I'm waiting on those parts to come =)
http://www.jegs.com/webapp/wcs/store...09070-300-8241 http://www.jegs.com/webapp/wcs/store...m=%09555-20580
Thank you god for all your blessings! My mini build (I had a great starting point) http://67-72chevytrucks.com/vboard/s...d.php?t=440743 Last edited by Bull72; 06-25-2011 at 07:45 PM. |
06-25-2011, 07:59 PM | #91 |
Yup, my buddies fan sure cools down his workshop. Definitely a plus in the South Texas summers of 100+ degrees I thank god that my M-F are spent indoors at Rackspace Hosting.
06-29-2011, 07:10 PM | #92 |
Found some more parts on sale today at Jegs (that was my excuse for spending money that I shouldn't be spending) These should be here by Friday
JEGS Performance Products 52009 - JEGS Universal Aluminum Radiators - on sale for $149 http://www.jegs.com/i/JEGS+Performan...52009/10002/-1 JEGS Performance Products 52116 - JEGS Dual Electric Cooling Fans - on sale $199 http://www.jegs.com/i/JEGS+Performan...52116/10002/-1 JEGS Performance Products 51060 - JEGS Premium Aluminum Water Pumps $79 http://www.jegs.com/i/JEGS+Performan...51060/10002/-1
07-03-2011, 02:35 AM | #93 |
Got some parts delivered today
And a little more progress: Clear coated the block, timing chain cover, and oil pan. We tack welded the oil pump and sealed the pan. Also since I got new push rods, thought a rocker arm upgrade was in order
07-05-2011, 10:12 AM | #94 |
Why weld the oil pump??
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
07-05-2011, 10:16 AM | #95 |
07-05-2011, 04:48 PM | #96 |
Exactly he said that they have come loose before so he put a small bead to ensure it did not come loose.
07-06-2011, 10:09 AM | #97 |
Ahhh rogerdodger
07-06-2011, 10:32 AM | #98 |
I always braize mine but welding works too. Not sure i would have welded it on the engine though. Engine is looking good.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
07-06-2011, 02:31 PM | #99 | |
We just put a bit of cardboard under there and hit it really quick. I guess it would have been a bit smarter to weld first then bolt on.
07-16-2011, 08:19 PM | #100 |
I just painted the engine bay today!!
First we hit it with the pressure washer. Once it was dry we scrubbed it really well so it was nice and clean. The previous owner painted it a few years ago black it actually looked pretty decent. We didn't really rough it up or sand it down just sprayed it all black again. My buddy has a paint gun, and he had some extra black paint. I just bought a little paint thinner and taped her up... Not exactly a 100% attention to every little detail here, but I didn't want to pay a shop to do it. I know it will look a lot better then before Here are the before pics, the tape and the gun... below is the finished wet product...
Thank you god for all your blessings! My mini build (I had a great starting point) http://67-72chevytrucks.com/vboard/s...d.php?t=440743 Last edited by Bull72; 07-16-2011 at 08:24 PM. |
