Old 09-20-2005, 12:43 PM   #1
70c10
67-72 Addict!
70c10's Avatar
How do rear roll pans mount on our trucks?
Fiberglass or steel.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-20-2005, 01:27 PM   #2
lowrider79
With sheet metal screws or bolts
lowrider79 is offline   Reply With Quote
Old 09-20-2005, 01:31 PM   #3
superfly68
superfly68's Avatar
metal with a welder... but be sure to knotch out an area so you can still get to the tailgate bolts!
no longer have a ride, but still a fan!
superfly68 is offline   Reply With Quote
Old 09-20-2005, 02:23 PM   #4
FormerMember
Ok, small high jack...
Where's a good place to get a good metal roll pan?
FormerMember is offline   Reply With Quote
Old 09-20-2005, 02:31 PM   #5
lowrider79
I bought mine at Chevy Duty and it fit well
Old 09-20-2005, 07:28 PM   #6
70c10
67-72 Addict!
70c10's Avatar
What I was getting at was do I still use my bumper brackets I have on the truck (fleetside) now?. Thanks
Jim
Old 09-20-2005, 07:39 PM   #7
Custom_C5
I don't think that you need brackets to use a rollpan on the back, I do know that in the front you have to cut some of the frame to make the front rollpan fit (so no bumper brackets on front)
Custom_C5 is offline   Reply With Quote
Old 09-20-2005, 07:57 PM   #8
70c10
67-72 Addict!
70c10's Avatar
It seems like it would need support in the center.
Jim
Old 09-21-2005, 08:28 AM   #9
MAR-Ktech
Truck Parts Mfg.
MAR-Ktech's Avatar
Rear pan installation
A steel rear pan generally attaches to the rear sill under the tailgate with screws and also is attached to the bedsides under the tailgate hinges by either welding or by screws and a small bracket. http://www.mar-k.com/rear_pan_installation.html and http://www.mar-k.com/rear_pans.pdf The Mar-K pan also requires notching the rear sill to provide clearance for the tag "box" because it is recessed about 2" and needs the opening cut in the rear sill for clearance. The bumper brackets must be removed as they interfere with the pan location. Once the pan is screwed to the rear sill and attached to the bedsides it is quite stable and should not need additional support.
Mar-Ktech
GET MAR-K Quality!
Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks
MAR-Ktech is offline   Reply With Quote
Old 09-21-2005, 08:40 AM   #10
70c10
67-72 Addict!
70c10's Avatar
Thanks Mar-k Tech!
Jim
