Old 11-11-2018, 01:28 AM   #1701
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good C10
With the paint cured, I started sticking things in holes. The way Retrosound has you install the radio, the knobs stick out from the dash too far and look funny, IMO. I used a set of factory AM radio mounting cups instead of their supplied washers/spacers along with modifying the faceplate and brackets to tuck the knobs in as close as possible to the dash. Much better, now
Still not sure on how I feel about the faux dial screen protector. I’ll leave it stuck on there for a while and see if it grows on me...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-11-2018, 01:36 AM   #1702
gringoloco
A guy with a truck
gringoloco's Avatar
Hmmm, maybe I’ll order one of these screen protectors instead; it looks a bit more appropriate for this era truck:
-Chris
Old 11-11-2018, 03:21 AM   #1703
smbrouss70
smbrouss70's Avatar
Looks way better than a single DIN radio in there. How does it sound?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 11-11-2018, 10:37 AM   #1704
gringoloco
A guy with a truck
gringoloco's Avatar
Unknown at this point, and probably for a while. It’s just mounted, not yet wired. Lots to do before I get to hear any sound outta this thing. Currently no battery, wiring harness, or fuse box installed.
First up, finish body work and paint firewall and engine, then install drivetrain for the last(?) time
-Chris
Old 11-12-2018, 08:31 AM   #1705
mcbassin
Still Learning
mcbassin's Avatar
Very nice work on the dash repair and the engine Chris!
Old 11-12-2018, 01:46 PM   #1706
knomadd
knomadd's Avatar
Nice work so far Chris! The dash is looking good.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 11-13-2018, 11:26 AM   #1707
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks dudes! Moved on to final clean, prep, and paint on the engine. Gotta say, I’m digging it
-Chris
Old 11-13-2018, 12:40 PM   #1708
smbrouss70
smbrouss70's Avatar
Mmmmmmmm, love me some Chevy Orange!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 11-13-2018, 01:49 PM   #1709
shearjs
shearjs's Avatar
Beautiful! Hope mine looks that good some day soon! What kind of paint did you use to spray the engine?
shearjs is offline   Reply With Quote
Old 11-13-2018, 04:22 PM   #1710
rustytruck50
rustytruck50's Avatar
Nice!!!!!!!!!!!!!!!!!!!!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 11-14-2018, 10:17 PM   #1711
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks guys, I’m diggin it. It’s sprayed with Seymour EN-48 which layed out really nicely
-Chris
Old 11-20-2018, 08:44 AM   #1712
mcbassin
Still Learning
mcbassin's Avatar
The engine looks great! Should be running by Christmas huh
Old 11-20-2018, 11:57 AM   #1713
gringoloco
A guy with a truck
gringoloco's Avatar
Ha! If I’m lucky, by summer. Time to start block sanding this firewall...
-Chris
Old 11-24-2018, 09:13 PM   #1714
gringoloco
A guy with a truck
gringoloco's Avatar
Welp, the firewall fooled me into thinking it was pretty flat, until I started block sanding it. I get the feeling there will be quite a few more rounds of making filler dust before this thing is ready for color...
-Chris
Old 11-24-2018, 09:35 PM   #1715
gringoloco
A guy with a truck
gringoloco's Avatar
I recently had a flashback to a few moths ago at HRPT with smbrouss70 and 65StreetCruiser. As we walked around checking out trucks, a comment was made regarding the “unfinished” look when the firewall isn’t properly capped where the blower motor used to be. I knew at that moment that I had work to do before this firewall could be declared officially complete. Thanks for unintentionally bringing this to my attention, Steven. This one’s for you
I welded in two strips of 18ga to closely replicate the look of the cowl panel edge and set them in at the same depth as the rest of the gutter. The whole business will get self-leveling sealer and should blend in seamlessly. Should... This is one of those mods you only notice if it’s not done, but I’m glad I took the time to make it look “right”.
-Chris
Old 11-24-2018, 09:44 PM   #1716
sprint_9
sprint_9's Avatar
Looks good, you will be glad you did it. Its probably one of my favorite things Ive done to my truck.
sprint_9 is offline   Reply With Quote
Old 11-25-2018, 11:16 AM   #1717
smbrouss70
smbrouss70's Avatar
Hey, if that's the worst thing I get blamed for, I'll take it! It does look much better when it's "finished" though. Good job.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 11-25-2018, 04:28 PM   #1718
rustytruck50
Well done, Chris! Those subtle mods are the best because they make you take a second look
-Doug
'05 RCSB Sierra 2WD
Old 11-26-2018, 02:16 PM   #1719
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Killer work Chris, firewall and engine look great! I love the Chevy orange.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 11-28-2018, 12:31 PM   #1720
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks dudes. Lotsa blocking going on to get this thing acceptable. Arms (and everything else) are sore
-Chris
Old 12-01-2018, 03:16 PM   #1721
65StreetCruiser
It Is What It Is
65StreetCruiser's Avatar
Just re-read through the whole thread again, Chris. What an amazing transformation from day one. Funny how these projects just keep evolving. Keep up the excellent work. Looking forward to seeing it on the road again.
Kevin
65 Chevy SWB Fleetside Custom Cab (sold, so long old friend it was a fun ride)
68 Chevy SWB Fleetside Custom Cab
68 Camaro convertible
www.louisianaclassictruckclub.com
65StreetCruiser is offline   Reply With Quote
Old 12-01-2018, 06:54 PM   #1722
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks Kevin! Driving yours definitely helped motivate me to get back on it. 13 years I’ve had this thing now; they’re never done...
-Chris
Old 12-02-2018, 05:05 PM   #1723
gringoloco
A guy with a truck
gringoloco's Avatar
Still chipping away at projects, consuming this elephant one bite at a time. Got the valve covers and adapters painted and installed:
-Chris
Old 12-02-2018, 05:11 PM   #1724
gringoloco
A guy with a truck
gringoloco's Avatar
Rebuilt the disgustingly crusty Hurst Muncie shifter and converted it from bayonette style to bolt on stick:
-Chris
Old 12-02-2018, 05:15 PM   #1725
gringoloco
A guy with a truck
gringoloco's Avatar
The Black Friday parts are beginning to trickle in. This trap door should flow a little more air than the stocker:
-Chris
