12-29-2015, 10:27 AM | #651 | |
Re: 1976 Square "Simple Green"
Yep mine is street only and I don't drive it in the rain either so i do t need ss braid or hardlines. Lmao you sound just like my wife telling me I could have bought a new one for what I have put in mine. She is correct but it would not be the same. And it seems like it is a never ending process. Lol. |
12-29-2015, 10:29 AM | #652 |
I will keep posting little FiTech tips for everyone. Cause they don't have them in the directions or on the website. Hopefully it will help people out so you can use the FiTech to its full potential.
Plus anymore issues I run into. |
12-29-2015, 10:34 AM | #653 |
So I ordered the 700r4. And ordered a direct bolt in 75-77 tranny crossmember no drilling cutting just bolt and go. And a few other things so the 700 would go in with no issues and work.
12-29-2015, 10:35 AM | #654 | |
It's like a kid to you and I bet if someone asks you questions about your truck you can talk to them for hours about what you did and why you did it and lets not forget about you showing pictures of what you did and what it looks like now. It's something your proud of. I see the looks on people faces when they make the mistake and ask me anything about my Jeep, it's the look of "oh crap, what did I just start " For some reason they never ask again unless they a Jeep person also. |
12-29-2015, 10:36 AM | #655 |
Yes please do and once I finally get mine I'll be re-reading this entire post and then probably bugging you with questions.
12-29-2015, 10:37 AM | #656 | |
12-29-2015, 10:38 AM | #657 |
12-29-2015, 10:38 AM | #658 | |
But Found Her 25yrs Later!
I think it's great. I plan on helping anyway I can with my research. If enough information is here, FiTech might like to get involved. It can't help but benefit them and the end user. (us). . BTW, I'm pretty settled on the 600 hp.
12-29-2015, 10:41 AM | #659 | |
600hp I believe you will really enjoy. It has everything you want and room to grow haha. |
12-29-2015, 10:48 AM | #660 |
I will be using this for my lockup control. I really like this setup. No pressure switches.
https://bowlertransmissions.com/p/10...control-module |
12-29-2015, 10:56 AM | #661 |
I just can't decide on torque converter go with a Yank or Circle D I really don't want to spend $1k on a torque converter.
12-29-2015, 12:24 PM | #662 |
Well swamp remember my post about a weather proof case for the FiTech handheld. Well I pitched my idea at Ken the big dawg at FiTech and he loved it lol. So it just may come true for you off road guys. A weather proof FiTech handheld case. Haha...
12-29-2015, 12:46 PM | #663 | |
Make sure you tell Ken you have at least one sold to me, as long as it's not $100. By the way I know you mounted yours, how did you mount it? Was there holes in the back or did you just Velcro it in place? Does it look like the holder they send can be permanently mounted or does it look like the handheld mount area separates from the base? |
12-29-2015, 12:55 PM | #664 | |
12-29-2015, 02:17 PM | #665 |
Ray here.
Has anybody tried the laptop software yet? As far as hand controllers my first one V2.1 had some issues keeping the cables in. My second one V2.2 has wider spacing for the upper cables but fell apart inside when I plugged the USB cable in. Fitech answer was...... are you ready....... The one in my car works just fine I cant see were anything can be wrong with yours... and I must be doing something wrong....I kind of just hung up at that point... So has anybody used the soft ware yet?? |
12-29-2015, 02:34 PM | #666 | |
12-29-2015, 02:49 PM | #667 |
Ray here.
I have the software working and it is very nice. The controller thing not so much.....3 phone calls and two e-mails later im informed its me. The rest of it I could not be happier with I will never put a carburetor back on.. Will try calling later in the week. Thanks for the reply... Ray. |
12-29-2015, 03:30 PM | #668 | |
12-29-2015, 05:39 PM | #669 |
Ray here.
I will try to explain this. Controller V2.1 has epoxy holding the UBC connecter and the card holder plus some other tiny thing in place (don't know what it is) ....see photo.. The cables plugins on the top are so close together the cables bind and wont stay in... Zip ties are your friend..... Controller V2.2 the epoxy has been left out.(But the top cable holes are wider) At the end of the UBC connation in the controller there is a plastic thing with the five or so of the wire contacts that is mildly crimped in place at best. So if for any reason your cable end is a bit long or you push to hard it will push the plastic thing out that has the wires in it.....contact over.... I'm thinking that's why V2.1 is epoxied? (see photo) At this point you take the controller apart and find the part floating around inside.. Push it back in and hold it while you insert the cable and move on.. NOW I could just epoxy or hot glue it at the risk of making more of a problem.. I don't see were I should have to do that.......But I may have to..... Ray. |
12-29-2015, 05:57 PM | #670 | |
12-29-2015, 06:00 PM | #671 |
How method/kit are you going to use to connect the 700R4 TV cable?
Made in America by Americans |
12-29-2015, 06:09 PM | #672 | |
http://m.summitracing.com/parts/lok-tcb-4150 |
12-29-2015, 06:26 PM | #673 |
Ray here.
The back of the controller did not fall apart. The back side of the UBC portal falls out its very very small and you have to take the back side of the controller off to see or fix it .....not hard.. And this is part of the problem most people have never seen the inside of UBC portal and have no idea what am talking about..they just plug in and go... Using the cable that was supplied with the kit... Ray. |
12-29-2015, 06:31 PM | #674 |
Ordered up the 700r4 crossmember from bowtie overdrives. Made specific for 75-77 c10 truck direct bolt in. I like direct bolt in makes life easy. But as most know sometimes direct bolt in does not happen all the time.
12-29-2015, 07:02 PM | #675 | |
I'm curious on who you talked to that gave you this answer. I called once and got a rather strange answer and I was wondering if it's the say person. Every place seems to have that one person who just goes through the motions. |
