03-01-2021, 11:42 PM | #1 |
387k tahoe gets new diff
Welp finally got tired of listening to the grinding ground of front diff on 387000 mile Tahoe. Picked up this beauty of a differential from local junkyard 22,000 documented miles on the truck will probably outlive the rest of the Tahoe looking forward to i stalling it ina few days
03-02-2021, 08:06 AM | #2 |
Re: 387k tahoe gets new diff
03-02-2021, 11:14 AM | #3 |
Was all them miles racked up on the original motor?
03-02-2021, 04:10 PM | #4 |
it got a engine and transmission at 369k not suren if trans was orginal but engine was orginal trans was out of and egnine was leaking alot of oil and running poor so i just swaped both for a 150k units
03-03-2021, 12:19 PM | #5 |
Its in old had had alot of metal shards on drain plug also found my 15 mm swivel scoket I lost 3 year ago when I did engine swap can't believe it rode there that long
03-05-2021, 12:02 PM | #6 |
Moderator
That's never good to find on the drain plugs.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
03-10-2021, 02:49 PM | #7 |
Is your hoe a full time auto unit? The front diffs live and die by routine service on the full auto units. You can draw out the 2x4 units a little on fluid changes though. I had co-worker I had to put one in an escalade that looked even worse at 105k because he never changed the fluid.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
03-10-2021, 02:52 PM | #8 | |
03-10-2021, 02:54 PM | #9 |
You're good to go now, fresh fluid every 75-100k, if it lives that long and you're golden!
03-10-2021, 02:56 PM | #10 |
Yup I also filled it with synthetic amsoil 75w90 gearoil
03-11-2021, 11:35 AM | #11 |
Moderator
I use a laundry soap pump and clear hose on bottles of gear, manual transmission, and transfer case oil but Amsoil really has a good gimmick with the bags.
03-11-2021, 11:43 AM | #12 |
03-11-2021, 12:41 PM | #13 |
Moderator
It's a really good idea. The packaging is likely a heckuva lot cheaper and it's a lot easier for the consumer to use. Winner all the way around
Even with the soap dispenser and hose it's still a pain in the neck to fill the diffs and transfer case on my 05.
