12-14-2014, 03:01 PM | #1 |
CST - Custom Sport Truck ???
Okay I picked up a clean 1969 CST C-20 which I am working to return close to stock but with a little performance twist for fun. The CST package of my truck consist of T-400 trans, 4:10 12 bolt rear end, full gauge package not including tach, and one you don't see to often on regular trucks is the light over the back window on top of the cab. Is there anything else about the CST trim I am missing? Thanks in advance for your help!
12-14-2014, 03:04 PM | #2 |
Re: CST - Custom Sport Truck ???
I just found this also: the cargo lamp became available in mid 69, and was included in the CST package.
From the dealers books; Stepside pickups and Cab/Chassis trucks; Full depth foam seat with delux vynl trim carpeting door trim panels chromed front bumper Cigar lighter Headliner Cargo lamp Bright condtrol knobs and pedal trim, rear window trim,wing vent trim,and windshield moulding trim CST fender name plates Bright side marker lamps Door operated dome light switches special insulation. Fleetsides or Longhorn models, add... lower body side mouldings with wood grain inserts Wood grain tailgate panel Tail light trim Bright fuel filler cap. |
12-14-2014, 03:07 PM | #3 |
Cluster King
CST = Custom Sport Truck and was the equivalent to the Cheyenne introduced in 1971.
Check you SPID and check under the seat for a build sheet. These two articles will have valuable information on what options came with your truck. SS Tim would be a great help for you to decode what you have. Take care, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
12-14-2014, 04:39 PM | #4 | |
12-14-2014, 04:44 PM | #5 |
Cluster King
That is good stuff and you are lucky to have that. Now you can match the numbers with your vin and make sure your seat was not swapped and go from there. This is better than Magnum P.I trying to decode and see what your truck came off the assembly line with.
12-14-2014, 05:09 PM | #6 |
Great day! Everything checks out on the truck. Turquoise & White with upper and lower molding is what she was built with. 350 and turbo 400. Engine is original along with transmission.... amazing how many numbers you have available to match things up... Even said chrome hupcaps... on the build sheet...
12-14-2014, 05:10 PM | #7 |
It will not go back completely the same but close enough for a family project.
12-14-2014, 05:40 PM | #8 |
My Glove box sheet is still there also.... along with a good hint of the original colors...
12-14-2014, 05:47 PM | #9 |
I wanna see the truck!
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
12-14-2014, 07:32 PM | #10 |
12-14-2014, 08:07 PM | #11 |
nice looking truck. CST is only a Custom Comfort and Appearance package with extra widgets installed to upgrade it from there - has nothing to do with tach, TH400, etc. It DOES give you all the items listed in the 69 brochure below:
Note - your CST emblem should not be present - it is superseded by the CustomCamper20 badge (Z81) on the fenders. If you had the emblems, that is, I see they've been shaved - but just wanted to mention. |
12-14-2014, 08:10 PM | #12 |
here's an additional 69 CST interior to drool over. Love red buckets...
12-14-2014, 08:46 PM | #13 |
Very good info!!!
12-14-2014, 09:09 PM | #14 |
The Older Generation
Looks like it originally had the 8.25 x 16.5 wheels on it too. They are pretty hard to find.... LockDoc
12-14-2014, 10:52 PM | #15 |
Moderator
Very nice!
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
12-15-2014, 12:17 AM | #16 |
I went with 16 steel wheels. Out getting powdercoated right now. Tires came in from Tirerack and cab/bed mount kit from LMC has also arrived. She will start looking normal/stock soon.
12-17-2015, 08:43 PM | #17 |
I am working on my second CST. This one comes with a factory auto trany, power steering, in dash ac, and power breaks.
My first build was a 69' CST Longhorn and this will be my last hotrod build...just feels fitting |
05-25-2018, 12:41 PM | #18 |
My CST/10 has all the options in the above posted brochure, but is the bright roof trim moldings a head liner? can someone explain.
thanks.
1969 CST/10 SWB, FS 396 BBC |
05-25-2018, 01:59 PM | #19 | |
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
