Old 06-19-2020, 05:13 AM   #226
OKGMC4
OKGMC4's Avatar
Re: Mr Green Jeans - the 69 (or not) chevy, er gmc, project
Starting to revisit the dash. Trying to decide where what goes. The unfortunate part is that when I dug out the glove box door I guess something rather heavy had fallen on it in the last 6 years or so. I’m making other arrangements. A blank sheet of metal looks so bland, so I broke out the punch tool again. I had almost forgotten I used it on the tailgate so it will sort of bring the theme inside.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 06-21-2020, 12:47 PM   #227
OKGMC4
OKGMC4's Avatar
Center section filled. Will probably put a touch screen double din stereo in there. And build a lower panel for a/c vents and controls. And make a new column mount since I can’t raise it enough to attach it in the new dash. (It’s held by zip ties right now) And modify the brake hanger to attach to the dash since they are miles apart now. Change one thing, change everything.
Old 07-27-2020, 09:35 PM   #228
OKGMC4
OKGMC4's Avatar
I did it! Ididit! ...is the brand of column I bought. Bad joke. Sorry. Making a panel below the dash for a/c vents and also mounting a panel for bag switches and two pressure gauges. Since the air bag stuff is going down there I’ll mount a single din head unit and the heat/ air controls up high.
Old 07-29-2020, 08:20 PM   #229
OKGMC4
OKGMC4's Avatar
I mounted the radio in my 56 gmc by cutting a hole and sliding it in. Always thought it should have been recessed but after paint who wants to cut and weld? This time I used angle iron and built a cubby hole. This radio will very nearly be flush. Now to mount a Vintage Air control panel in there...
Old 07-30-2020, 11:56 AM   #230
curtisb
OK, im impressed with this work. beautiful
curtisb is offline   Reply With Quote
Old 07-30-2020, 05:48 PM   #231
OKGMC4
OKGMC4's Avatar
Thank you. I really appreciate it!
Old 07-30-2020, 05:49 PM   #232
OKGMC4
OKGMC4's Avatar
Should work.
Old 09-13-2020, 06:05 AM   #233
OKGMC4
OKGMC4's Avatar
I like the VHX gauges I got for this truck but had to make a change. Dakota Digital doesn’t make individual gauges for the set I got and I wanted to add a boost and afr gauge for the turbo. I don’t want a mess of mismatched gauges cobbled together in random places on the dash. So I ordered some custom built gauges from Speedhut to fit my instrument cluster. Now I can achieve zen by having everything in its proper place. Besides, it just wouldn’t be right if I didn’t do every part of this truck at least twice.
Old 09-13-2020, 06:44 AM   #234
72 tigger
72 tigger's Avatar
Very nice gauges and fab skills
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is online now   Reply With Quote
Old 10-26-2020, 07:31 AM   #235
OKGMC4
OKGMC4's Avatar
Moving to a new home. Rolling a truck downhill with no steering is fun. Couldn’t have done it without my dad, my father in law , and my son in law helping. Moving sucks!
Old 10-28-2020, 09:03 AM   #236
cornerstone
cornerstone's Avatar
Originally Posted by OKGMC4 View Post
Moving sucks!
I can agree with that one!
On a positive note, the truck out of the garage allows us to see the proportions you chose. I think you nailed it man! It looks like it could have rolled off the GM line... that is to say if they ever made one! Cool build!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 11-12-2020, 08:14 AM   #237
OKGMC4
OKGMC4's Avatar
Trying to get settled. In the last couple weeks I’ve painted 5 rooms and built an 8x8 shed. Trying some lights I found on Amazon. I bought a 12 pack of T5 linkable led lights and installed 8 of them on the big bay side of the garage. They are as bright as my old garage was with 20 F32T8 fluorescent bulbs. I’ll install the last 4 in the small bay side and should be good. @ $80 for 12 it’s a good price, too.
Old 11-14-2020, 01:37 PM   #238
cornerstone
Wow. The lighting in your shop is great! Hard to believe you can get that much lighting for only 80 bucks... and be way more efficient! Nice upgrade
Brian
Old 03-06-2024, 01:41 PM   #239
OKGMC4
OKGMC4's Avatar
I’m starting back on this truck but taking a very very different path to completion. I feel like it will be easier to start from scratch since most of what I’ve already done won’t be used. I’m starting a new thread here…
hopefully I can actually finish the truck this time and stick with a plan. I thought about parting it out but would rather finish it than cut it up. I’ve already cut up and threw away a 70 Chevelle and 70 RS Camaro in the past. Still kicking my own behind for that even though all the parts went into my 79 trans am and 56 gmc.
