08-23-2019, 08:31 AM | #26 |
Re: What goes here? (Interior bedside gap)
Looks like a decent alternative, long enough to experiment with rolling over the ends.
08-24-2019, 04:43 PM | #27 |
Equal opportunity joke ofender
Another thought would be to use the long suburban panel strips. They are about 71" on the long side and would only require one cut. they are the same profile as the upper door panel strips The short side is about 47'' . I probably still have some from part outs but would have to look
Anybody have a length on the Blazer ones? .
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
01-14-2020, 07:17 PM | #28 |
OK, an update on this little issue and another question for someone knowledgeable.
Update: I ended up ordering stainless tile edging cutting it to length, manually rolling the ends, then polishing the hell out of it. They turned our incredibly nice. So, I ended up with a very believable set of "retainers" as the assembly manual called them for ~$90 plus some work. Not bad. But, a quick question - does the [protective sheet metal box for the filler-neck stay on underneath the rear vinyl panels? If so it's going to create a funky gap. Anyone know how the CST's were built WRT that piece? |
01-14-2020, 08:38 PM | #29 |
Carpe manana
Nice work.
Factory CST K5s lacked that cover for the metal fuel filler neck, which the panels covered. The cover was used on non-CST K5s.
01-14-2020, 08:41 PM | #30 |
01-21-2020, 10:59 AM | #31 | |
01-21-2020, 11:36 PM | #32 |
Those trim pieces look good! How did you roll the ends? Could you post some close-up pics?
Thank you. Jeff |
06-01-2020, 02:26 PM | #33 |
I finally wrapped the side-panel project today. Honestly, the trim rails turned out amazing! I ended up using a combination of pop-rivets and 3M trim adhesive (the really thin stuff) to bond them to the bed rails. Unless you REALLY know what the original profile looked like I don't think anyone would ever suspect these aren't factory.
06-01-2020, 02:38 PM | #34 |
I actually just rolled them using some needle nose pliers. I cut the profile I wanted, then used the pliers to gradually roll the stainless over on the end. Then sanded it, and polished the hell out of it. Here are some pictures of the roll before polishing.
06-08-2020, 03:11 PM | #35 |
Looks awesome!! Good idea.
06-09-2020, 04:03 PM | #36 |
Just got these back from being refinished
They look brand new
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
06-09-2020, 10:19 PM | #37 |
Not exactly related to the fantastic mod you made to the trim pieces, but I like the setup you did with the speakers and the CST bedside panels. Not sure i'll be able to bring myself to cut a couple holes in the panels that i get, but i like the classic looks of the panels coupled with a high quality sound system.
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858 |
06-10-2020, 02:17 PM | #38 | |
06-10-2020, 02:21 PM | #39 | |
Making the subwoofer enclosure was a whole other journey. The bedsides are so shallow that there was almost no tolerance to fit the sub. I had to use the inner bedside as a mold and lay up fiberglass to create the back panel, then used 1/2" baltic birch for the sides and faceplate. Then used chopped fiberglass and epoxy resin to reinforce all the joints. Ugh... But, it sounds great! Last edited by harrij4; 06-10-2020 at 02:33 PM. |
06-14-2020, 11:11 PM | #40 |
This is exactly what I'm needing to do to my Jimmy.
What tile trim did you get from home depot? Was it an in stock item or did you need to special order it Harrij4?
you never have too many suburbans.... |
06-14-2020, 11:20 PM | #41 | |
It's Schluter Rondec 3/8 stainless bullnose edging (not brushed). Here's a link if the system doesn't remove it: https://www.homedepot.com/p/Schluter...100E/202608906 |
