07-20-2019, 07:38 PM | #1 |
Active Member
How far to go...
So I pulled a perfectly running engine that didn't use any oil or smoke. I removed it because the rear main seal and oil pan were leaking. So my plan was to simply re-gasket, clean and install. I have a few people telling me that I should pull the heads, check the valves etc... How far should I really go?
07-20-2019, 07:45 PM | #2 |
Re: How far to go...
Put it back together and back in the truck or either a complete rebuild. If it was running good why spend the money but if you are going to spend money on it you might as well do it right.
Personally I would put it back in and run it as long as it will last then buy a crate engine to replace it. |
07-20-2019, 07:50 PM | #3 |
How much money do you want to spend ?
If your happy with the way it ran before .Toss a new oil pump in it (Melling ) re gasket and some new paint and your good to go ... being as these engines were built to be repaired without using a 10 mm if it ain't broke don't fix it .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
07-21-2019, 09:26 AM | #4 |
I’m with Grumpy. But if it were mine and it was that far apart it would be getting a new timing chain along with the oil pump and I couldn’t see NOT putting an RV type cam in it. But here we are with project creep....
Check out the Elgin Cams on Competition Products site or the Howards with the 5 year no fault warranty. But I would do a timing chain and oil pump even if the cam stayed stock.
07-21-2019, 10:02 AM | #5 | |
Project creep ? What's that ...
07-21-2019, 11:52 AM | #6 |
I did this...ended up spending a bunch of $$ on roller cam retrofit and head work...then more $$ to swap to electric cooling fans... love it!!! What should you do? Go big or just put it back together w/paint and run it. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
07-21-2019, 12:08 PM | #7 |
If she has good oil pressure and compression just reseal and go. The only other check I would make is pull and check the base of each lifter for excessive wear.
Steve weim55 Colorado |
07-21-2019, 12:17 PM | #8 |
If you know any of the history of the engine that should help with your situation. If you do not know any history of it, personally, if I were at the point you are, I'd at least pull bearing caps and check the bearings and I'd reseal the whole thing. I would also replace the oil pump with a high volume pump, or at least a good quality new replacement. Id also replace the freeze plugs at least in the rear if you are not sure how old they are.
07-23-2019, 03:58 PM | #9 |
Sub'd, I'm in the same predicament and looking for the same info.
72 C10 lwb fleetside -stock 350/350 combo |
07-23-2019, 04:03 PM | #10 | |
07-23-2019, 04:17 PM | #11 |
Go Pack Go!
Stay with your original intent. New timing chain and gears with new oil pump is good advice.
07-23-2019, 06:53 PM | #12 |
How many miles on it?
07-24-2019, 07:44 AM | #13 |
Active Member
Mileage is unknown, I believe it has been gone through in the past. I decided to take the advice and replace the oil pump and timing chain, seal things up and put it back in.
07-24-2019, 11:12 AM | #14 |
All about them K’s
Pump,chain, re seal and let it eat.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
07-24-2019, 01:40 PM | #15 |
Maybe even a new water pump since you already have the old one off.
07-25-2019, 02:43 AM | #16 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
07-25-2019, 03:07 AM | #17 |
I was in a similar situation with the engine in my truck. When I pulled the engine for a reseal and rolled it upside down on the engine stand, about 3 cups of black sludge dumped out on the garage floor even thought I had drained the oil previously.
That lead to the removal of the crank bearing caps which were noted as being scored and discolored from old oil. At this point the engine was done internally, so we ordered a low buck crate engine for $1375 shipped. That was the smartest thing done to this truck. So, how clean is this engine inside?
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
