07-17-2019, 03:37 PM | #1 |
Dark Green Pearl
DARK GREEN PEARL is a High Gloss, With High Sparkle Silver Metallic, & Red Pearl,
Acrylic Enamel, Single Stage Paint. What color base would you guys recommend? |
07-17-2019, 10:33 PM | #2 |
Re: Dark Green Pearl
Some options to consider:
1) Don't ask a single stage acrylic enamel (or the more durable urethane option) to give you likeable results when asking for anything but solid colors. They don't do well with metallics like a base coat / clear coat system can provide. (did you notice I didn't even mention pearls!?) 2) single stage paints don't have a base - they dry shiny all by themselves without the need for a clear coat. 3) take the suggestions you like most and then spray them all out on crash panels (body shops have lots) and put them out in the sun, shade and leave them there and look at them until you can decide what you like. The end result is very important and you have to be sure you will love it, otherwise, don't paint the entire vehicle "hoping" you will before actually seeing it. Another thing to consider when picking a color is the level of perfection with the body work. The lighter the color the more sin it hides...the darker the color, the more imperfections it shows. Ever look a black classic that looks like hell? One that looks like a mirror? There's about 500 hours in body work difference between the two.
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
07-17-2019, 10:55 PM | #3 | |
Great advice, I hope I can keep this train of thought When I get ready to Paint. .
07-18-2019, 09:31 AM | #4 |
TYVM for your very detailed reply. Was trying to find a "modern" update of original color and going by what seller had in the listing-------------------------
"Mix is 8 Parts Paint, 1 Part Hardener, and 2 Parts Reducer.This is a transparent paint, and should have a one color primer / sealer under it." As you can tell I know nothing about painting a vehicle other than getting the prep work right. |
07-19-2019, 07:35 AM | #5 |
If you have never painted before are you sure you want to try a translucent paint? Candies, pearls and translucent paints are the most difficult even for the most experience.
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
07-21-2019, 09:11 PM | #6 |
Good advice above. What you want can be done, but not exactly easy....it takes a few extra steps to pull it off. I also wanted an updated color, mixed my own urethane base coat, metallic is going to be more difficult to get an even spray on your parts/ or complete truck. Body work, epoxy primer, filler etc before you get to the far turn....on mine Silver base coat on everything before the Green metallic went over it. 3 coats of Silver, 4 coats of Green metallic, 5 coats clear. the green is not translucent, Probably could have skipped the silver, but the practice may have helped getting dialed in.
07-22-2019, 08:42 AM | #7 |
Looks great. I can only hope---------------------
07-22-2019, 10:10 AM | #8 |
Painting videos on YouTube will also help.
07-22-2019, 03:04 PM | #9 |
notsolo that does look good, what color did you end up with then I assume custom?
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
07-22-2019, 03:26 PM | #10 |
Thanks for the comps...yep custom mix. TCP Global qts of metallic base coat....UMB...4 qts .lime firemist... 1 qt gold...1qt silver...price has gone up $20.00 a qt since I did mine...There paint is decent....thicker than Nason.....thinner than Ppg dbc...
08-01-2019, 03:17 PM | #11 |
