09-18-2019, 11:26 PM | #226 |
I'm trying....
Re: 1969 K10 CST Full Restoration
Thanks. It was a butt kicker. But as they say...fourth time's a charm.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
09-19-2019, 10:46 AM | #227 |
Brad, Amazon has a supplier that sells the seat springs in custom cut lengths. There are different gauges for seat back or seat bottom. I don't know if I have any pics of the ones I bought or not, but they are supplied by HotSign Springs and looked just like the originals, with the ends bent properly to fit onto the seat frames. The small wires you spoke about that look like paper clips can apparently be procured from some of the Corvette parts suppliers, as they use them as well.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Coming soon: EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 Last edited by 70STOVEBOLT; 09-19-2019 at 11:29 AM. |
09-19-2019, 10:49 AM | #228 |
Carpe manana
Sprint to the finish. Looking great.
09-19-2019, 10:57 AM | #229 | |
I'm trying....
That is solid info. Thanks. I searched the board and actually used a board member's recommendation on wsusol.com. The springs were the same gauge wire, just the wavelength was different. And we did have to cut them to length but it wasn't a big deal. I honestly didn't look for the small "paper clips" (that is a very good way to describe them btw), because by using the wire we did, we could easily set and level the inset detail by tightening or loosening the twist. Since they're together and look good, I'm probably not going to revisit those things. But I've got another set of seats to do for my K20...I will remember your recommendation.
09-19-2019, 10:58 AM | #230 |
I'm trying....
Thanks. Won't be long. Bummed though, we're going to miss Maggie Valley. Wasn't for lack of trying.
09-19-2019, 10:43 PM | #231 |
I'm trying....
A/C is buttoned up and ready for charging (I hope). The condenser wasn't a dead ringer for the original (though it was basically anatomically correct). We are staying with our original '69 hard lines, which means hoses and clamps. Jim (FirstOwner69) has been very gracious and shared pics of his original truck to use as reference. And I have many times--again here with A/C hose length and routing.
09-21-2019, 04:44 PM | #232 |
I'm trying....
Seats buttoned up with freshly phosphated mounting brackets. Ready to go in just waiting on final paint and rear window install.
Seeing the '69 only (or maybe '69 and a few '70s) smooth rearview mirror cover (Thanks Madkidd007) installed makes me wish I'd tried harder to come up with a '69 only perforated headliner. You gotta pick your battles and I wimped out on that one I guess.
09-21-2019, 04:46 PM | #233 |
I'm trying....
I love the look of these 12 points on the hood latch. Unfortunately I don't have a pic to confirm that these were ever on a '69. I sent a lot of bolts in to get plated and all were sourced from either a '69 or '70. Sadly, at this point I can't remember which these came from. I like the look so much I think I'm going to let them ride unless someone tells me it never happened.
What I think is unusual is that on the '71 one owner (that we tend to lean on as a reference because it's a one owner original) has the "anchor head" version of these...but they are only in the top two (core support side) positions...the others are 6 point. I only had these two in my re-plated stash, so I suspect a similar situation on the truck from which they were pulled. Do you think it'd be because the grille was attached at a different point on the assembly line from the latch? I've seen trucks where they(hood latch bolts) were all 12 point. It just seems like another oddity to just have the two.
09-21-2019, 05:56 PM | #234 | |
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
09-22-2019, 07:29 PM | #235 |
I'm trying....
The Falcons looked crummy today so it was a good day to work on some small jobs. I got a R59 battery topper and an NOS Delco Eye...actually I had to get two...(Apparently the inside of a truck tool box in Georgia gets pretty hot)... My original plan was to remove the yellow and repaint the lettering red, then mill the NOS Eye down to fit the topper. But I couldn't get the paint to look right. So I changed gears...
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 09-22-2019 at 08:38 PM. |
09-22-2019, 07:33 PM | #236 |
I'm trying....
I removed the clear plastic from the one that got a little goofy in the tool box and milled it to fit the repro Delco Eye. Cut it to length and polished the bottom back to clear.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 09-22-2019 at 07:56 PM. |
09-22-2019, 07:35 PM | #237 |
I'm trying....
It's a simple group 24 battery. I took the topper around to a couple of stores and picked the one it fit best. It still required a little refinement and adjustment of the terminal holes to get it to seat all the way down. Still needs a little green tape under the eye to make it look spot on. (Looked for those NOS Delco spring ring terminal ends like ChewyChevy67 found--those things look so cool...no luck though).
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 09-23-2019 at 09:22 PM. |
09-22-2019, 07:46 PM | #238 |
I'm trying....
And went ahead and cut the carpet and installed what could be installed. It's as far as it can go for now. Just paint for a bit.
09-23-2019, 09:08 AM | #239 |
Proprietor of Dale's Corner
I didn't know a battery topper existed. Pretty cool.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
09-23-2019, 10:25 AM | #240 |
I am blown away by your attention to detail and knowledge in achieving the true definition of a restoration here.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
09-23-2019, 01:03 PM | #241 |
I'm trying....
It's about $340 for a full reproduction Delco R59. This route has the advantage of being easily transferable to a new battery when the time comes. The thing that really holds the toppers back though is the Delco Eye. You'd think they'd at least paint it green or something. It gives the thing up from a mile away. That's why we decided to improve that aspect.
Thanks. But as I said before I'm just taking advantage of others' willingness to share on this site and elsewhere. I got the idea to fix the Delco Eye on the topper from a thread on either a Chevelle or Camaro site. I looked for weeks to find spring ring terminals because I saw ChewyChevy67s...and Eric and I talked a fair bit about putting the bed on the rotisserie yesterday after tristan's most recent update for Project Checkbook 2. This board is full of inspiration, information and motivation.
09-23-2019, 01:16 PM | #242 |
Your topper now looks more legit than my battery cause your eye looks clear and the repo battery it's black. Nice work.
09-23-2019, 02:47 PM | #243 |
I'm trying....
Thanks. It's a trade off. My battery sides are slick and don't say Delco like an original R59.
09-29-2019, 03:19 AM | #244 |
Location: Oregon, The Beautiful Pacific Northwest (GOD'S country)
I'm jumpin in a bit late but I'm in for the remainder of the ride! I haven't finished getting up to speed yet nor have I looked at your Blazer build... yet, but I am amazed at your attention to detail and knowledge. Can't wait to see the finished result!!
In GOD I Trust All Others I Question!!! 1969 Chevy CST K/10 SWB (Legs) 1969 Chevy C/20 LWB (Old Gray Mare) Donor 1972 GMC 1500 Sierra Grande (Orange Creamsicle) Sold 1979 Chevy C/30 Cheyenne Flatbed Dually (FatBoy) Sold 1991 Chevy Silverado Ext Cab (LowBoy) Sold 2008 Harley Davidson Electra Glide (Black Betty) Mark ~ US ARMY VETERAN 2nd ARMORED DIVISION 67th ARMOR |
09-29-2019, 08:11 PM | #245 |
I'm trying....
Thanks for the kind words...and for jumping on board!
09-29-2019, 08:22 PM | #246 |
I'm trying....
Eric elected to paint the bed floor, header and inner bedsides separately. Primarily for access and control. It meant the hardware had to be painted separately too which will make assembly difficult/tense...but that is the theme of the build. Considering reach, run potential and polishibility(is that a word?)...it's hard to argue with this approach.
09-29-2019, 08:40 PM | #247 |
I'm trying....
In the meantime I was fighting the hubcaps. You know once I'd like to get on here and say 'see this...it was a piece of cake'. But that's not tonight. Again followed Pete's lead and sent our caps to Electroplating of El Paso for polishing. They were fast and did a nice job. After some consideration, we elected to paint the caps instead of going the vinyl route. Though after having done it, I'm of two minds still. Pete was kind enough to share some vinyl spares (Thanks again Pete!) that I used as stencils. I felt I had enough texture to paint directly to the stainless...but I was wrong. I had areas of poor adhesion...so I stripped it, re-taped and started over. This time I thoroughly scotchbrited(made up word for sure) the area after tape and laid down a coat of self etching primer. Thankfully that did the trick. Semi gloss black enamel and Rustoleum Sail Blue (as prescribed elsewhere on the board).
09-29-2019, 09:12 PM | #248 |
Carpe manana
Caps turned out great! Hope those helped. Not sure why Chevrolet decided to exchange blue bow ties for gold.
I’d love to see how GM caps were originally painted in quantity. There must have been a stencil involved.
09-29-2019, 09:22 PM | #249 | |
I'm trying....
Me too...and had to be a stencil. Another instance where I could not accomplish in two days what they did in probably 60 seconds. And their paint stuck the first time and lasted for 50 years.
09-30-2019, 02:39 AM | #250 |
Those caps look awesome! You've definitely outdone the factory!
Tags |
1969, 4x4, cst, k10, swb |
