Old 02-05-2009, 12:04 AM   #1
LuckyHenriksen
LuckyHenriksen's Avatar
Difference Between......
An oil temp gauge and an oil pressure gauge? Which one is better
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 02-05-2009, 12:09 AM   #2
Select
Friday's Toy
Select's Avatar
Re: Difference Between......
If it were me I'd rather have the pressure gauge.
68 C10, SWB Fleetside with a 454, Turbo 400 and 4.11 posi....Exxon/Mobil loves me.
2009 Jeep Rubicon
2011 Powerstroke FX4 (totaled)
71 C10, SWB Fleet with factory tilt
72 LWB C10, 350 700R4 with factory tilt
Select is offline   Reply With Quote
Old 02-05-2009, 12:11 AM   #3
lpaine
lpaine's Avatar
I'd say the pressure gauge is more valuable/critical..
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 02-05-2009, 12:12 AM   #4
Indyuke
Depends on what you want to keep tabs on. I would say an oil pressure gauge is a must for all vehicles, because it can give a good indication of the overall health of an engine.
An oil temp gauge will tell you the "true" engine temperature, because whatever temp the oil is, that's generally what temp the engine block itself will be. The heads will be a little hotter, and some guys run CHT (cylinder head temp) gauges. Coolant temp isn't a good indication of engine temp.
I'd rather have the oil pressure gauge.
Indyuke is offline   Reply With Quote
Old 02-05-2009, 12:27 AM   #5
LuckyHenriksen
Good deal
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 02-05-2009, 02:07 PM   #6
thirdstreettito
Resident of Here
thirdstreettito's Avatar
I have both in my 84. I prefer both, rather than one.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 02-05-2009, 04:39 PM   #7
Oil pressure and water temperature are absolute musts and oil temp is good to know.In my`72 K2500 I run an oil temp gauge off my automatic transmission.That way you have an eye on the motor and trans temp seperately.And,one will affect the other.It helps me know which is the cause of high temps.
Old 02-05-2009, 08:42 PM   #8
Gray Ghost
Gray Ghost's Avatar
Oil pressure is way more important than temp to me.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
