09-08-2019, 10:31 AM | #1 |
How to Dull Out an Acrylic Enamel Paint Job???
My truck has a decent gray acrylic enamel paint job (3 heavy coats) and I have sanded the gloss finish off of the hood. I am liking the dull finish that 600 grit wet sand paper has yield besides some evidence swirls/clouding which I hope to work out with more sanding...
I would like to consider dulling out the whole truck...does dulling the finish substantially compromise the life of the paint job? This truck will see about 3000 miles a year as I plan to drive it to work, rain or shine, but no driving in the snow. What are my dull/satin options at this point that won't leave my paint degrading sooner than later? I am fine with a primer look even though sanding the paint to that finish is harder that gaining it with primer alone.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
09-10-2019, 12:59 PM | #2 |
Re: How to Dull Out an Acrylic Enamel Paint Job???
is this a solid or metallic color?
if it is a solid color you can wetsand with 600 and spray SPI universal clear with their flattening agent there is a post with great pictures. |
09-11-2019, 06:51 AM | #3 |
It's a solid gray. It will be mistaken for primer if I can achieve the right finish. Thanks for the clear coat advice...I will keep it in mind.
Does my sanded paint need clear coated to avoid near future paint failure? Will the clear coat make the sanding scratches disappear?
09-11-2019, 10:42 AM | #4 | |
a simple scuff with maroon scotch brite and 2 coats of clear flattened to desired amt will provide best protection |
09-15-2019, 01:43 PM | #5 |
Thanks a million Marty! Given the choice of a primer look with the issues of keeping it clean, matte finish without the primer look, or what gloss I can get from enamel... I'll see how the gloss look settles in with me. If don't like it once assembled, maybe I'll knock the shine off with some 2000 grit.
In 20 years it'll be faded and old looking anyhow, I hope to still be around..lol.
