01-21-2019, 11:37 PM | #1 |
Sticking valves fix??
So I got s small block that has been sitting for several years.
Seems like valves are sticking. Thinking intake bit maybe an exhaust or two also, not sure. So I've heard pouring marvel mystery oil down carb , in gas tank and also adding it to the oil. Seafoam help? I was going to take valve covers off and spray some penetrating oil around the valve stems. And add mystery to the oil. Any suggestions or info greatly appreciated. low mileage engine. Thanks Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
01-21-2019, 11:44 PM | #2 |
Re: Sticking valves fix??
You stole my answer. Marvel Mystery Oil.
01-22-2019, 12:04 AM | #3 |
I'd try adding a bottle of Techron to the tank and running some GM top engine cleaner down the carburetor.
01-22-2019, 12:04 AM | #4 |
If MMO can't unstick the lifters they have to come out.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
01-22-2019, 09:41 AM | #5 |
so in with the oil and gas tank? eventually in know the engine will need gone through but want to get it running better so it can be moved when needed.
thanks! Mark
01-22-2019, 10:38 AM | #6 |
I'm very interested in replies to this thread. I have a 72 C20 with a 350 that sat for many years before I purchased it (truck only has 25,000 miles on it). I oiled the cylinders, let it sit and then turned it over by hand prior to starting it. I got it running real well but it has had continual lifter noise for the past year. I added MMO to the oil initially and after 100 miles or so changed the oil and added Rislone to the oil. Neither has helped the noise but it has been running great so I didn't care.
Then the other say coming home from work it wanted to die every time I came to a stop (won't idle). Looked for vacuum leaks and ignition issues but can't find the problem. I then noticed an "air puffing" type of sound from the tailpipe that wasn't there before and am wondering if there is a valve train issue? Therefore I am definitely interested in any types of additives that I could use to solve my issue.
Dave R. 1972 K20 1972 C20 Highlander 1957 Chevy 210 Delray 1967 C10 |
01-22-2019, 12:25 PM | #7 |
Are we talking about the valves possibly sticking in the guides or lifters being stubborn??? Just wondering...
Marvel mystery oil is good stuff, auto trans fluid works quite well, and is cheaper, as far as adding something to the oil...trans fluid has a boat of detergent in it. There is more than one company that makes foaming penetrating types of lubricants, I just don't remember any right now, been a while since I needed such a product. Most come with a straw, similar to WD40. I would seek out a foaming penetrant, and shoot some into the insides of the valve springs. Maybe even do this 2-3 times, before attempting to start engine...couldn't hurt anything... |
01-22-2019, 05:47 PM | #8 | |
To OP if the valves are sticking I have used mmo and pb blaster to lube the valve stem . On a 6 cylinder I once had to actually tap the valve and spring with a hammer and pry it back up. This was before I got the engine broke free. A 63 lark with 22k original miles . I bought it in 1980 the car had sat untouched in a basement garage since 1968. Have to say the car ran great after a few hundred miles.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
01-22-2019, 08:02 PM | #9 | |
01-22-2019, 08:13 PM | #10 | |
Good luck, I hope you are all shoveled out ! Russ |
01-23-2019, 12:18 AM | #11 | |
Although the OP isn't specific as to what he means by sticking valves, in my experience the most common causes for valve train noise are sticking lifters or maladjusted rockers. If it's rockers, they need to be adjusted; if it's sticking lifters, Marvel is the best I have found.
01-23-2019, 08:55 AM | #12 |
Valves are known to stick if you get a motor running that has gas that is mostly gone bad. Lots of times fresh fuel will be splashed in to get it running then the poor fuel will actually fire on the warm engine. But when the engine is shut off, the varnished fuel deposits CAN cause the valves to stick. This may not be related to your problems at all, but hopefully will help someone thinking about running a vehicle that has been sitting a long time.
Water can help, but be VERY judicious in it’s application. ATF is also used to help clean the engine top end while running and requires the same slow, metered application.
01-23-2019, 01:44 PM | #13 | |
Russ |
01-23-2019, 04:01 PM | #14 |
Lifters will stick also, hard sometimes to determine which it is. Good oil will help. My lifters stick all the time on startup when it is cold, I just give it a little rev up to 2 grand and get the oil up there in the lifter valley.
Summertime no issues. |
01-23-2019, 07:42 PM | #15 |
Mine has a ticking sound on cylinder 7 but hopefully it’s just a blowing header gasket
01-23-2019, 09:40 PM | #16 |
Thanks for all the replies!
I'm going to adjust the valves first and see how it runs ad sounds. Definitely one or two hanging up. I'll report back once I dig into it. Mark
01-24-2019, 06:14 AM | #17 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
A proven home made penetrant is a 50/50 mix of ATF and Acetone. I like to take it a step further and add an equal amount of Marvels Mystery Oil. While your running them valves give them stems a liberal dose of the above mixture. And while your right there with the socket wrench, swing that rocker off the top of the valve stem and hit the top of the valve stem with a hard rubber hammer or the end of the wooden handle of a 4lb hammer. Just a couple of whacks hard enough to open and close the valve a couple times. Do that to each valve paying attention to the sound of each valve. Keep them stems wet with the penetrant while you do this. After you get the valves adjusted and the motor running, pour a little MMO down each throat of the carb. You can follow up with some SeaFoam down the carb to help that MMO get to them valves as well as clean things up a bit. Make sure those push rods are open and the MMO in a squirt bottle will help getting the oil in the ends of the rods and delivered right down to the lifter that may be dry or dirty. Inline fours such as the Z1 are notorious for carbon build up and a squirt through the exhaust ports and in the intake ports gets right on them valves, and the hammer handle trick will usually jar any carbon chunks loose and reseat the valve. Always use an oil with ZDDP in it such as Mag-1 or Valvoline, I'd use a 5w30 with a quart of Rislone or MMO in the crank case...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
01-24-2019, 12:14 PM | #18 |
Liqui Molley makes a valve cleaning product that is increasing...
71 C-20 07 Magnum RT AWD |
01-24-2019, 03:11 PM | #19 |
X2 on that Valvoline VR1. I believe its the main cause of my engine still running! It is a very high quality oil.
01-24-2019, 08:42 PM | #20 |
Sounds like a collapsed lifter. It must be ticking.
I just had to do this with my low mile, little use 327 in my 64 impala ss. I pulled the valve cover and poured the mystery oil right down the pushrods to the lifters. I then fired it up every day and ran it for about 10 minutes to get warm, then shut off. Did that for 3 days and it released. I changed the oil and all is good.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
