Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-20-2019, 01:42 PM   #1
Awann99
Cab lighting issue.
Recently I swapped a corvette steering column in my 1969 gmc 1500 that the previous owner had installed for an original one. I rewired the column connector like the original. My dome stopped working and then now my light in my cluster are no coming on. My bright light indicator comes in and my brake light comes on when I start it. The gauges are working properly but there isn’t any light. I checked the fuses and they are all good. Any ideas. I also just swapped my brake light lenses and now they will not come on. The only light I have at night are my headlights. Could it just be a bad light switch?
Awann99 is offline   Reply With Quote
Old 10-22-2019, 10:45 PM   #2
Wrenchbender Ret
Re: Cab lighting issue.
Sure sounds like a blown fuse. The brake lights & dome light are on the same circuit.
The rest I don't know off hand. You need a test light & wireing circuit.
George
Wrenchbender Ret is offline   Reply With Quote
Old 10-22-2019, 10:55 PM   #3
franken
If you pulled the dash/guage bezel out I bet the ground wire isn't connected... It clips onto the metal dash If I recall.
Old 10-25-2019, 10:30 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Cab lighting issue.
All your problems started when you swapped out the column. All the lights go through the column wiring harness. That's where I would start look. The wiring diagrams are at the top of the page and are a must to have and use for this type of stuff.
Take a good look at your main dash harnes connection also. You may have not gotten it plugged in good.
I found this on my daughters 68 dash yesterday when taking it a part.
This was the main connection and the grey wire was the main feed wire for all the lights. I had to cut it and splice it. Not to mention all the paint on the terminals!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-25-2019, 11:59 AM   #5
Awann99
Thanks for the links. I’ll take a look. I found a blown fuses and now I have turn signals and hazards but no running lights as well.
Old 10-25-2019, 12:28 PM   #6
Dead Parrot
If your 69 is like my 68 Impala was, the dash lights are on the same circuit as the park/running lights. And it is a different circuit/fuse from the brake/turn lights.
Dead Parrot is offline   Reply With Quote
