Old 09-18-2020, 01:02 PM   #1
Harold Holbrook
Need Help
I have a 1971 chevy blazer 350 with air short water pump. I have 3 pulleys on the crank 2 on the water pump. cant get the power steering pump to line up. Did they make a power steering pump that was different for AC or pulley?
Harold Holbrook is offline   Reply With Quote
Old 09-19-2020, 08:37 AM   #2
jaros44sr
jaros44sr's Avatar
Re: Need Help
You may have the wrong brackets on your pump post up a pic of your setup we may be able to help by that, there are a lot of people on here with stock set ups
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-20-2020, 09:01 AM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Need Help
That’s my guess too. Pump and or pump brackets.
Old 09-21-2020, 10:32 AM   #4
notsolo
notsolo's Avatar
Re: Need Help
Should look something like this, I used a couple flat washers behind mine to line it up correctly....photo's from someone with a clean shop...not mine.
notsolo is offline   Reply With Quote
Old 09-21-2020, 11:23 AM   #5
Harold Holbrook
Re: Need Help
Notsolo : That looks like what I have, I have to learn how to post photos
Old 09-21-2020, 02:48 PM   #6
Harold Holbrook
Re: Need Help
My pump sticks out past the pulleys .
Old 09-22-2020, 02:06 PM   #7
1rippen6
Re: Need Help
Here's Harold's setup, the power steering pulley is beyond the crank pulley. When he bought the blazer it had the wrong pump so he pieced everything together. It's a 71 with factory air do they use a different pump or pulley or both than none a/c and if so does anyone have part numbers.
1rippen6 is offline   Reply With Quote
Old 09-22-2020, 03:56 PM   #8
Harold Holbrook
Re: Need Help
Thanks, Dwayne for posting pictures for me.
Old 09-22-2020, 04:00 PM   #9
Richard
Re: Need Help
A simple pulley change on the pump should fix you up. Your pulley is inline with the hub, need one that offsets back. Did a quick search for "71 chevy truck power steering pulley" Quite a few came up. If you do not have a PS pulley puller/installer will have to buy or rent.
Richard
Old 09-22-2020, 04:00 PM   #10
Harold Holbrook
Re: Need Help
I think it is the pulley, look at the pictures that notsolo posted the pulley has a longer nose on it.
Old 09-22-2020, 04:03 PM   #11
Harold Holbrook
Re: Need Help
Richard, I think you are write, Now I have to find that pulley with the longer nose on it.
Old 09-22-2020, 04:05 PM   #12
Richard
Re: Need Help
Does not have a longer nose. On your pulley the belt groove is inline with the hub. On the other it is dished back from the hub. Understand? Not sure if yours has keyway? https://www.amazon.com/Team-Performa...GNZANGRM95AZYQ
Richard
Old 09-22-2020, 04:51 PM   #13
Harold Holbrook
Re: Need Help
Yes Richard, Thanks to all. I will let you know how I make out.
Old 09-22-2020, 07:22 PM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Need Help
I took a look at mine. The Blazer has a four groove pulley on the crank (CA emissions AIR equipped) and a flat pulley on the pump. The k20 has a three groove pulley on the crank and a “recessed” pulley on the pump. Both have AC. The K20 engine was shifted forward to accommodate a 700r4 transmission hence the tighter space.
Edit: the pump and presumably the pulley are original to the Blazer per the date code on the pump.
Last edited by DeadheadNM; 09-22-2020 at 07:25 PM. Reason: POS iPad correction error
Old 09-23-2020, 08:40 PM   #15
Harold Holbrook
Re: Need Help
Thanks, Deadhead I just ordered a dish pulley ,the one on my pump is flat like the 4 grove pulley.
Old 09-23-2020, 09:13 PM   #16
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Need Help
You bet. Hope that fixes it. Keep us posted.
Old 09-25-2020, 04:43 AM   #17
Richard
Re: Need Help
X2. Let us know how it works out.
Richard
Old 09-30-2020, 02:03 PM   #18
Harold Holbrook
Re: Need Help
Got my dish pulley today still no luck. I am looking at crank pulley.
Old 09-30-2020, 07:29 PM   #19
1rippen6
Re: Need Help
Here is what he has now but I believe possible he has the right crank pulley. According to the link below Classic Bowties recommends a different power steering pulley than the one he just bought.
http://67-72chevytrucks.com/vboard/s...ghlight=pulley
Old 09-30-2020, 07:32 PM   #20
1rippen6
Re: Need Help
Post 3 states he needs power steering pulley 3993325, here is what he has now.
Old 10-02-2020, 10:38 PM   #21
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Need Help
Could a wider than stock harmonic balancer be displacing a correct pulley?
Here are the sections from the parts book for crank and PS pulleys. Note the p/n on your crankshaft pulley is for a 3/4-1t non-PS application and a 307 motor and others w no PS. You need the correct one for PS.
Old 10-02-2020, 10:53 PM   #22
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Need Help
Maybe these will do the trick?: https://www.ebay.com/itm/1963-68-GM-...oAAOSwp-Zcq7vG
Old 10-02-2020, 10:58 PM   #23
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Need Help
Looks like this part number is also needed.
Old 10-02-2020, 11:20 PM   #24
Harold Holbrook
Re: Need Help
The right part number is 3993325DJ
Old 10-03-2020, 07:08 AM   #25
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Need Help
Note the GM parts manual doesn’t list DJ or any other suffix to the part number.
