Old 02-08-2011, 02:04 AM   #76
otef546
Junior Member
Re: Big block engine bay pics!!
Originally Posted by otef546 View Post
ok I sure will but I'm away from home and just have my lap top, when I get home tomorrow I'll find some for ya
Well I found some on the lap top
otef546 is offline   Reply With Quote
Old 02-08-2011, 02:08 AM   #77
VA72C10
VA72C10
VA72C10's Avatar
thanks for the pics!
Old 02-09-2011, 06:43 AM   #78
clos69
Its Topless Season!!!!
clos69's Avatar
Nice....are you planning on using a clutch fan or electric fans? Also what year specific did you get the reverse water pump?Thanks
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 02-09-2011, 06:58 AM   #79
royo
royo's Avatar
How do you guys put the motors and stuff in these trucks. with out scratching or denting any thing They all look good
nickle and dime
royo is offline   Reply With Quote
Old 02-09-2011, 11:45 AM   #80
71c10bbsuper
71c10bbsuper's Avatar
here are a couple of mineName:  bruce's truck 068.jpg
Name:  bruce's truck 069.jpg
Name:  bruce's truck 065.jpg
71c10bbsuper is offline   Reply With Quote
Old 02-09-2011, 12:34 PM   #81
RenoKeene
Florida Edition
RenoKeene's Avatar
Originally Posted by 71c10bbsuper View Post
Is that a Chevelle air cleaner?
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 02-09-2011, 12:39 PM   #82
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I don't know either, but it sure looks right at home on there. Very nice compartment.
Zoomin is offline   Reply With Quote
Old 02-09-2011, 12:45 PM   #83
RenoKeene
Florida Edition
RenoKeene's Avatar
I sure would like to have one for my build
Old 02-09-2011, 03:26 PM   #84
otef546
Junior Member
Hi , I used a pair of electric fans, a 12" and a 16" together covered the whole rad. Works great. Here's part of the instructions that come with the kit with the water pump details.
Additional parts needed to complete the engine (not included in this kit):
Use driver side and passenger side aluminum drive brackets off of a 1990-1994 Chevy 350 V8 or 4.3L V6 truck, with casting numbers 10118701 (driver's side) and 10118751 (passenger side). These are the brackets shown below. Notice that the passenger side bracket does not have an arm for mounting an air pump. Also notice the zigzag pattern ribs at the top of the driver's side bracket under the alternator. These brackets were used for other years and models too. A salvage yard or GM dealer may be able to help find them. See pictures. The passenger side bracket should include the idler and tensioner.
Air conditioner compressor and pulley, alternator and pulley, and power steering pump and pulley off the donor engine. Note: A good reason to use 1994 truck parts is that the compressor will use R134a refrigerant
A water pump pulley off the donor engine. Do not use a pulley with a groove. The belt surface must be smooth. GM part number 10085760 is suitable.
A reverse rotation water pump off of a 1988-1999 454 engine. This is considered a “long” pump, and is 7 5/16” from block to pulley mounting surface.
A big-block crankshaft pulley, GM part number 10085753.
Gates belt number K060970 or equivalent 6-rib 97” belt. This assumes the use of the 1994 truck brackets listed above and the belt routed inside the idler as shown below. The idler pulley can be omitted if desired. If the idler is not used, a 96" belt should be used.
A new thermostat housing may be needed to allow the upper radiator hose to clear the alternator. The Chevelle shown below is using a swivel-neck housing. Upper radiator hose will probably need to change, but your vehicle's stock lower hose, may work
Old 02-09-2011, 03:42 PM   #85
VA72C10
VA72C10
VA72C10's Avatar
Thanks for the awesome detailed info!!!!
Old 02-09-2011, 05:05 PM   #86
clos69
clos69's Avatar
Yes thank u for the info... Im thinking about going this route with my 454...also on ur electric fans,did u buy a kit or purchased them seperate and adapted them to the rad??Any pics of that setup? Much appreciated thx
-Carlos-
The of America
Old 02-09-2011, 05:15 PM   #87
cooter472
cooter472's Avatar
My old heap 472 Big Block Buick
71 C10 2WD,472 Big Block Buick
B4B Intake,800 cfm Q-Jet built by(Fred Catlin)
Comp Cam 254/268@ .050 .530/542 lift
1 7/8 supercomp headers, 2 1/2 X-Pipe/ Magnaflow's
Mallory fuel system
Igniter Flame thrower Ignition system
TH350,Hughes 3500 Converter ,3.73's
Its just an old heap, but its my hot rod!
cooter472 is offline   Reply With Quote
Old 02-09-2011, 07:15 PM   #88
otef546
Junior Member
I just bought the fans seperate and then wired them to work together .I also bought a relay kit with a temp.sending/sensor unit. I bought it all from a ebay seller by the name of skip white performance.They were priced really well so I had my doubts but they have been on there for a while and have done great.
Old 02-09-2011, 10:10 PM   #89
BossHogg69
motor exploder
BossHogg69's Avatar
Top pic is of my '69 before I tore my truck apart. It's a '79 GMC 454 out of a 3/4 ton.
Bottom pic is my engine bay now, minus the bay
I also have a serp belt drive for it, but it's off an '89 454 TBI motor (from a dually). Also running Hedman Elites. Very nice headers, but I had the motor mocked up to check clearance on them and ended up having to dimple the #1tube (drivers side) to clear the motor mount frame bracket
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 02-09-2011, 11:47 PM   #90
clos69
clos69's Avatar
Very nice Adam....So your Elites did not fit with 72 motor mounts?? I've heard that if you use F-body headers for Chevelle or Camaros...they have a better fit....does anyone know if this is true?? thanks
-Carlos-
The of America
Old 02-10-2011, 01:06 AM   #91
otef546
Junior Member
Hi , I used the 72 type big block mounts and my Elites went on with out touching any part of the frame however it was very tight on the pass. side and i was afraid after the motor ran a little the elites would end up touching the frame.So I ended up relieving the frame on the pass. side about 1/4 inch and then it was fine.
Old 02-10-2011, 06:10 AM   #92
clos69
clos69's Avatar
Thx for all ur helpful info.....
-Carlos-
The of America
Old 02-10-2011, 11:00 AM   #93
BossHogg69
motor exploder
BossHogg69's Avatar
I circled below where I had to dimple the header. When I say dimple, I mean just a small bit with the round end of a ball peen hammer. It was the hump there on the motor mount plate that was hitting. They won't bolt up all the way until I did this. And yes, these are original '72 mm's, but obviously not original to my '69. Maybe that has something to do with it? I did have to whack it pretty good to persuade it, but that is a good thing because these headers are very heavy built and solid - no cheap, thin metal on these at all. All in all really no big deal, as pretty much every set of headers I've ever used needed something 'extra' to bolt on all the way.
Adam
Old 02-10-2011, 12:56 PM   #94
BossHogg69
motor exploder
BossHogg69's Avatar
Adam
Old 02-10-2011, 01:06 PM   #95
DANTIP
DANTIP's Avatar
Originally Posted by BossHogg69 View Post
I call that a German fit. Gutentight! Very Nice!
DANTIP is offline   Reply With Quote
Old 02-10-2011, 02:36 PM   #96
Schilla67
Schilla67's Avatar
here's a pic of mine before i tore the whole truck apart a few years ago.
Schilla67 is offline   Reply With Quote
Old 02-10-2011, 03:00 PM   #97
mrh33916
Project '67 454
mrh33916's Avatar
Here's my '67,
67 C-10 SWB Fleetside 454 (current project)
99 Crewcab SWB Dually 454
75 Datsun 280ZZ430
94 Formula 232LS 454
mrh33916 is offline   Reply With Quote
Old 02-10-2011, 03:27 PM   #98
clos69
clos69's Avatar
^^^Very nice and clean!...the only thing I would change is the air cleaner like hobby67stepside used on his...the satin black chevrolet air cleaner.
-Carlos-
The of America
Old 02-10-2011, 06:52 PM   #99
BossHogg69
motor exploder
BossHogg69's Avatar
Originally Posted by mrh33916 View Post
Nice work on that firewall!
Adam
Old 02-10-2011, 06:56 PM   #100
bfay17
Young Gun
bfay17's Avatar
This is the best i can do for right now. There is just to much snow to shovel off and move
1968 chevy c10 soon to have 454 and turbo 4006
1970 custom/20 4x4 454/sm465/np205 around 7 inches of lift with 36's.
1992 2wd sierra 5.7 with edelbrock intake, headers, and a Chip. Posi rear with 235/75/15 tires.
Soon to have a few more upgrades
2003 ccsb 1500hd
bfay17 is offline   Reply With Quote
