09-23-2017, 09:16 PM | #1 |
Blue LED under dash and behind seats accent lighting
I've always been fascinated with interior accent lighting, heck I'm also into exterior accent lighting but this post is just the beginning of the lighting.
Fairly simple install, parts were cheap and time was a few hours. I added a total of 4 blue LED lights, two under the dash and two behind the seat. LED's were from Super Bright LEDs https://www.superbrightleds.com/more...les/miniature- rectangle-led-accent-light-black/25/ Add-A-Fuse from Amazon https://www.amazon.com/Radar-Mount-D...rds=add+a+fuse The rest was just simple wiring connectors and 18 gauge wire for power and ground. I added the Add-A-Fuse to the fuse panel and jumped the Dashlights circuit so it comes on with my headlight. I soldered the wiring to make clean connections. The ground in the dash was just added to a screw as the body is the ground. And in the rear, I just drilled a hole in the top crease to make a ground. The pics aren't the best but you can tell how it will look. As you might know, photographing lighting never comes out clearly but you can see how they look. I've included 3 pics. First - From inside the cab looking under the dash. Second - From inside the bed looking inside the truck. Third -Form the front of the truck looking inside. For about $32 and a few hours of time, I think it's pretty bad ass! |
09-23-2017, 11:56 PM | #2 |
Re: Blue LED under dash and behind seats accent lighting
I like it!
09-24-2017, 12:39 AM | #3 |
I had those in my old 74...one of the coolest things i ever did to it. Also put blue leds in the cluster and my sunpro tach. Plan to do it to my 83
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
09-24-2017, 08:43 AM | #4 |
I like it!!!
I added LED lighting in my truck, just under the dash and then my door plates. I used white under the dash. I guess I never thought about using a color. I got a under the dash kit from LMC and added those 2 to the 2 that were already there, so 4 all together. And then I also upgraded the dome light and put a LED bulb in it too.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
09-24-2017, 05:08 PM | #5 |
This is a great idea. Thinking I'm going to do it in mine and wire it to the door switches since my dome light doesn't work. I think this would be better than fixing the dome light.
1978 GMC K25 1984 Chevy Scottsdale K10 built 350 4"lift - SOLD |
09-24-2017, 09:44 PM | #6 |
Proud Vet that loves the USA
Looks sexy fellas. I dig those sill plates....
Bubba |
09-24-2017, 11:00 PM | #7 |
09-24-2017, 11:26 PM | #8 |
Most issues with the dome light and/or courtesy lights are the door switches. The terminals usually rust and fall off the back of the door switches. I had this on my truck, my dome light & courtesy lights did not work. After doing some tracing, I found my wires were no longer attached to the back of the switches. They were laying in in the bottom, between the panels. So I got some new ones and reattached the terminals and "Then There Was Light"!!!
09-24-2017, 11:39 PM | #9 | |
09-24-2017, 11:42 PM | #10 |
Were there 2 wires on the left side/drivers side? Should be 2 wires on the left and 1 on the right side.
09-25-2017, 02:15 PM | #11 |
Yes those wires were solid, both sides replaced. I checked under the dash and found the one bulb in the middle and checked those wires and connections and all were good, I did not find another light anywhere else. Thanks for your help!
09-25-2017, 02:19 PM | #12 |
What I meant was, there should be 2 wires that go to the back of the left side door switch and 1 wire that goes to the back of the right side door switch.
09-25-2017, 07:42 PM | #13 | |
There was indeed two wires on the drivers side door switch and one wire on the passenger side door switch. |
