Old 09-20-2017, 07:45 PM   #1
jronc2004
65 chevy c10 rear coil spring
i installed new rear coil springs and trailing arm bushings with tracking arm rear end is offcentered by 1/2 anyone have any ideas why? adjustable tracking arm i see my only fix
jronc2004 is offline   Reply With Quote
Old 09-20-2017, 08:46 PM   #2
Clyde65
Clyde65's Avatar
Re: 65 chevy c10 rear coil spring
Check you track arm bushings
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-21-2017, 02:40 AM   #3
andrewmp6
Did you get lowering springs or are they stock height ?
Old 09-21-2017, 08:33 AM   #4
jronc2004
old tracking arm was bent, so i replaced it with new tracking arm and new bushings im kind of wondering far fetched but if bracket is bent 1/2 seems like alot though
Old 09-21-2017, 08:34 AM   #5
jronc2004
it is stock height
Old 09-21-2017, 08:45 AM   #6
jronc2004
i read on a forum somewhere that there tracking arm length was 24 inches center to center on there 64-66 chevy truck , mine is 23 1/2, there would be my 1/2 but doesnt make sense bought new from lmc truck
Old 09-21-2017, 01:17 PM   #7
PGSigns
PGSigns's Avatar
Is the truck complete or going together? Reason I ask is if all the weight is no on it it will be off to one side. Also it it is only a 1/4" off on the length. Mine was off a bit to one side with no load in the truck but when I used it as a truck it was pretty centered. Now that is has been lowered and has the long track bar on it it changes very little between unloaded and a bed full of mulch.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-21-2017, 03:57 PM   #8
jronc2004
Jimmy
its stock hieght, its off 1/2 , 1 inch to one side. i have the bed on it . ive had truck for years, have drove it quite a bit cant tell with handling of it, just noticeable when you really look. it cant be right. has to be in tracking arm i figure, somehow, too short bent bracket or stud
Old 09-23-2017, 10:37 PM   #9
jronc2004
thanks for ideas ,i figured out why my rear end was off so bad , may sound kind of dumb but as i was asked about stock height, im thinking it is , but today it dawned on me, i added rear air shocks when i installed new trailing arm bushings and tracking arm i let air out of shocks to almost nothing and it is within 1/4 i think ill go back to set of gas shocks
Old 09-25-2017, 07:28 AM   #10
PGSigns
PGSigns's Avatar
The short track bars move the rear a good bit as they travel. That is greatly improved with the long bars. As an added bonus it lowers the roll center to improve the handling.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
