04-13-2021, 04:53 PM | #1 |
Automatic tilt steering column
GM van tilt converted to a truck tilt. Has the correct length splined shaft, the neutral safety switch has been moved to the correct place on the column & the hole where neutral safety switch was is filled back in making the column look like a true truck tilt. The column was cleaned, painted, bearings checked & greased & had the following new parts installed to make this column like new. New turn signal switch & wiring harness with correct horse shoe wire connector, turn signal & tilt levers, indicator housing & lense, warning flasher knob, upper & lower rubber seals, neutral safety switch, & air seal on shift tube. Shift lever is a used truck lever in great shape. Steering wheel nut & horn contact with spring also included. Good tight column ready to bolt in. I build a wood crate to ship these in so they can make it thru shipping. I can only accept postal money orders at this time.
$ 525.00 Shipped / Shipping to U.S. only. No shipping to Alaska or Hawaii Posted via Mobile Device |
04-16-2021, 03:25 PM | #2 |
Re: Automatic tilt steering column
SOLD
