Old 02-01-2010, 10:52 PM   #76
lonestarluck
lonestarluck's Avatar
Re: Project: Recycle
nice work!
lonestarluck is offline   Reply With Quote
Old 02-02-2010, 12:01 AM   #77
garry bennett
dvcawefg
GB
garry bennett is offline   Reply With Quote
Old 02-03-2010, 12:30 PM   #78
LooseCannon
Subscribed!
LooseCannon is offline   Reply With Quote
Old 02-03-2010, 12:33 PM   #79
Preacherman5555
Preacherman5555's Avatar
Nice work
Preacherman5555 is offline   Reply With Quote
Old 02-09-2010, 12:43 AM   #80
SCOTI
SCOTI's Avatar
Not much progress as I'm trying to source parts which ultimately effect planning direction....
I picked up the aluminum material that will be used for re-positioning the rear axles center-line back approx 1.5". My plan was to utilize a solid piece of alum but the limited size & amount I needed rendered a significant jump in price. I decided to go w/what was readily available & used some 'drop' material from my local steel yard. One local metal supplier wanted $70+ for what I needed (which I had a few choice words for), so my steel yard let me scour through their alum scrap stack & these 2pcs (.500" x 3" x 21" total) cost me < $7. I'll have to stack them but it really won't impact their function....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-09-2010, 12:59 AM   #81
SCOTI
SCOTI's Avatar
While @ the steel yard, I also picked up some 4.5" OD steel pipe needed to complete some new rear bag mounting 'hats'.
The rear suspension was originally set up w/OE truck arms & shop built 2" lowering blocks which put the bag @ the exact installed height needed. I've since swapped some Porterbuilt 3" drop TA's which altered my height requirements. My c-notch is the limiting factor on ride height so even w/the 3" dropped TA's vs. the OE TA's w/2" block, I don't get any more drop. The PB TA's do allow me to use the 'hats' for mounting the bag which means no drilling a bunch of holes in the frame. I can also adjust the exact height of the hat so the bag travel & compression is optimal (which I did ).
Instead of the upper stud being centered in the mounting plate/hat, it will be off-set which allows me to use the existing OE coil-spring mounting holes even though the rear is not @ the OE dimensions. In the last pic, the OE upper hole location is just inside of the leading edge of the round tube....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-09-2010, 01:11 AM   #82
SCOTI
SCOTI's Avatar
I've still been searching for a smooth, flat, square fuel-fill 'door' but haven't been able to hit the local wrecking yards. I've been walking through my local parking lots documenting vehicle types that might be possible donors.
If I can't find what I want, I went ahead & sourced the part needed for 'Plan-B'. It's stainless steel, 1.5" OD fill tube (1.25" ID), & relatively small. I've seen them used & like their simplicity but I'll need to do something to eliminate the 'shiny' appearance. The last pic is an example of a similar set-up installed....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-09-2010, 07:10 AM   #83
n2billet
Village Idiot....
n2billet's Avatar
What about bead blasting it and then flat clear it?
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 02-09-2010, 08:42 AM   #84
my67chevytruck
Under Construction
my67chevytruck's Avatar
Nice progress Scoti.....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-09-2010, 09:54 AM   #85
SCOTI
SCOTI's Avatar
I'm thinking more along the Darth Vader look & make it disappear w/the bed liner. You still in town?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-09-2010, 10:42 AM   #86
aggie91
I'm just glad to be here!
aggie91's Avatar
Scoti - I thought that the Porterbuilt TA's moved the center line of the rear axle back that 1.5"? or am I missing something?? What about just moving the cross member back the required 1.5"?
On another note, can you get a measurement for me? I no longer have a stock rear end houseing. I need to know how far part the mounting pads on the axle are? A measurement from the center of the rear hole (for the u-bolt) to the center of the other rear hole and the same for the front holes would be helpful. Thanks in advance.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-09-2010, 11:40 AM   #87
SCOTI
SCOTI's Avatar
The PB arms are the same length (and adjustable). The PB TA c.member has the option to shift the rear axle back (different set of holes from what I remember). I'm using an ECE c.member that I already had so I didn't get the PB unit.
As for moving the c.member back, that's one method among several options. I figured by using the alum spacers, I can fine tune the exact dimension I want vs. drilling more holes & limiting the placement options (what if I need more/less that I thought??).
I'll try & get you those housing pad dimensions tonight.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-15-2010, 04:42 PM   #88
aggie91
aggie91's Avatar
Thanks Scoti!
Karl
The LST Challenge:
Old 02-15-2010, 05:15 PM   #89
SCOTI
SCOTI's Avatar
Thanks Scoti!
The recent weather plus my work schedule kept me from the shop from Wednesday on. I should get back out there tonight or tomorrow.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-15-2010, 05:52 PM   #90
MacAttack
283 Drama Queen
MacAttack's Avatar
Great score on the material!
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 02-16-2010, 12:02 AM   #91
aggie91
aggie91's Avatar
I fully understand. No worries, whenever you get it, I am still a ways from that part of my build. Thanks again.
Karl
The LST Challenge:
Old 02-17-2010, 02:00 AM   #92
SCOTI
SCOTI's Avatar
I worked late but managed to source the necessary hardware for completing the truck-arm spacers. Maybe tomorrow I'll get some 'quality time' @ the shop & finish welding the rear bag hats (and take a couple measurements )....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-18-2010, 01:55 AM   #93
SCOTI
SCOTI's Avatar
Chip . . .... chip.... chip. A little here, a little there; progress is progress.
I finished up the rear bag 'hats' (well.... almost). I still need to add a stud that will align w/the top OE frame hole for the spring (it will be offset to accomodate the set-back on the rear end). I didn't have long enough bolts so I'll source them & get these wrapped up by this weekend.
The set-back worked out just right as the 'hat' just nudges the rear OE rivets that retain the reinforcement plate for the springs. Installed (ride) height for the bags is 6-6.5". When dumped, they should hit the internal bump-stop @ the same time the axle tube bottoms out on the frame c-notch....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-18-2010, 09:12 AM   #94
my67chevytruck
Under Construction
Nice work Scoti!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 02-18-2010, 09:46 AM   #95
MattA
MattA's Avatar
Looks good, another scratch on the list.
MattA is offline   Reply With Quote
Old 02-18-2010, 09:51 AM   #96
VA72C10
VA72C10
VA72C10's Avatar
nicely done!!!
Old 02-18-2010, 11:11 AM   #97
SCOTI
SCOTI's Avatar
Thanks guys!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-18-2010, 12:30 PM   #98
Dinos63
chevy only
Dinos63's Avatar
HOLY SH-T WHAT A NICE JOB!!! this is going to be a badd a$$ , i love the fact how clean you work and how precise you fab stuff is, the quality of your work is killer nice job kat!!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 02-18-2010, 02:53 PM   #99
Frizzle Fry
Frizzle Fry's Avatar
Just found this and subscribed. Love the upper shock mounts and exhaust route path Scoti. I went with 1" longer PB arms and figure the adjustable del spheres will give me enough room to play with fore/aft. Might have to use the spacers on my 64 though. BTW, I'm in Austin next week. Might have no choice but to check this baddog out
Frizzle Fry is offline   Reply With Quote
Old 02-18-2010, 02:56 PM   #100
64Fugly
64Fugly's Avatar
Good job it is really looking good.
65' C10 (working on cab currently)
06' Silverado
64Fugly is offline   Reply With Quote
