Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 04-16-2020, 11:07 AM   #1
MikeCofield
Blazer steps
Here is the last set of blazer steps $300 plus shipping and pp fees . These are stainless and very nice
MikeCofield is offline   Reply With Quote
Old 04-16-2020, 11:11 AM   #2
MikeCofield
Re: Blazer steps
Pic2
Old 04-16-2020, 11:17 AM   #3
MikeCofield
Re: Blazer steps
Pic3
Old 04-16-2020, 11:17 AM   #4
aotte1
Re: Blazer steps
I will take them
Les
aotte1 is offline   Reply With Quote
Old 04-16-2020, 11:17 AM   #5
Terrysch
Re: Blazer steps
I bought a set of these steps that Mike had made.
They really are nice.
Thanks Mike for having these steps made.
Terry
Terrysch is offline   Reply With Quote
Old 04-16-2020, 11:18 AM   #6
MikeCofield
Re: Blazer steps
Pic4
Old 04-16-2020, 11:29 AM   #7
MikeCofield
Re: Blazer steps
Thanks terry these are nice additions
Old 04-16-2020, 12:31 PM   #8
MikeCofield
Re: Blazer steps
Wow these didn’t last 30 seconds . Will have a few more sets soon
Old 04-16-2020, 04:59 PM   #9
tmontg01
tmontg01's Avatar
Re: Blazer steps
These are built very nicely. Still need to mount mine on
1968 C10 SWB 400SBC with VN327 20's
1972 K5 Blazer 383SBC
2011 Cadillac CTSV
tmontg01 is offline   Reply With Quote
Old 04-16-2020, 05:01 PM   #10
MikeCofield
Re: Blazer steps
Tmontg01 thank you sir ... your blazer looks really good
Old 04-16-2020, 05:06 PM   #11
tmontg01
tmontg01's Avatar
Re: Blazer steps
Would you happen to have pics on the underside as to where they mount?
2011 Cadillac CTSV
Old 04-16-2020, 06:27 PM   #12
MikeCofield
Re: Blazer steps
I think Pete deadhead May have posted a pic
Old 04-16-2020, 08:48 PM   #13
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Blazer steps
Old 04-17-2020, 05:20 PM   #14
68panelman
68panelman's Avatar
Re: Blazer steps
Anybody have a pic mounted?
68panelman is offline   Reply With Quote
Old 04-17-2020, 09:51 PM   #15
mortoyz
Active Member
Re: Blazer steps
Here's a few pictures of the steps I bought from Mike. Very nice quality. Let me know if you need any other pics.
mortoyz is offline   Reply With Quote
Old 04-17-2020, 09:55 PM   #16
68panelman
68panelman's Avatar
Re: Blazer steps
Thank you. Can you do me another favor and measure the rocker pinch weld to the step mesh?
Looks about 4 inches?
Old 04-17-2020, 10:03 PM   #17
mortoyz
Active Member
Re: Blazer steps
About 4.25 inches. Much easier for my wife to get in and out of the Blazer with the aux steps.
Old 04-17-2020, 10:08 PM   #18
68panelman
68panelman's Avatar
Re: Blazer steps
Thanks man, really appreciate it.
I'd be installing for same purpose, for wife and passengers, I'm always yelling to not step on the rocker panel! Hahaha
Old 04-17-2020, 10:11 PM   #19
mortoyz
Active Member
Re: Blazer steps
You're welcome. I'm not gonna lie, I use them also...
Old 04-17-2020, 10:29 PM   #20
Killer Bee
Killer Bee's Avatar
Re: Blazer steps
WoW those are nice Mike!
anyone know if they fit suburbans? third door?
thanks!
Old 04-18-2020, 07:57 AM   #21
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Blazer steps
thanks!
This style attaches to the flat undersurface of the torsion box. My recollection is that subs do not have torsion boxes so I don’t believe these will work. GM made a style for pickups - those should work but these partially require use of holes in the floor pan.
Old 04-18-2020, 08:14 AM   #22
Killer Bee
Killer Bee's Avatar
Re: Blazer steps
thank you! that's what I was afraid of.. I'll probably go the route Ptjsk did and customize for my application..
I really like the expanded metal tread plate steps on our F450/F550 utility trucks at work..
a little modernish looking but simple and beefy enough to pass for vintage..
keep up the good work Mike, those are great vintage steps for some lucky Blazer/Jimmy owners!
Old 04-18-2020, 11:17 AM   #23
Terrysch
Re: Blazer steps
Killer Bee,
Another option for you would be to use these steps from Mike and then modify the underside arms. Extend the arms that mount to the torsion/rocker boxes so the arms mount to the frames. Because the most important part of these vintage look steps are the horizontal steps/platforms.
I am modifying the steps to fit my Jimmy.
Why?
Because I installed a rear sway bar on my Jimmy.
That meant that the dual exhaust that I had installed is routed where the torsion/rocker boxes I have are to be reinstalled. So I am modifying the torsion boxes to go under the rerouted exhaust.
This meant I have to modify the steps I purchased from Mike.
Before I purchased the steps from Mike I reviewed with Dale, a friend of mine who is a fabricator welder guru, to make sure this would work.
Doing this work because I wanted the sway bar for safety, dual exhaust and the vintage look stainless steel steps from Mike.
But for you this does involve getting arm extension stainless steel tubing. Plus you or someone who welds stainless
Pete/DeadheadNM - thank you for calling the rocker boxes torsion boxes. Not everyone understands the true purpose and f
Old 04-18-2020, 11:35 AM   #24
Terrysch
Re: Blazer steps
Finishing my last post. Had a PC problem and had to reboot.
Not everyone understand the purpose, function of the rocker boxes.
The are what Pete correctly called them. They are really torsion boxes.
They are for adding torsional rigidity to the outsideareas of the Blazers/Jimmys vehicles when the top is removed and the Blazers/Jimmys are used as convertibles. Ouside of the central main frame. Frame still does this in the center of these vehicles.
Some people believe that you do not need them if you have a rollover bar assembly. This is not correct.
Because the torsion boxes connect between the A pillar and the B pillar wall area, and then further back under the bed in these vehicles.
The roll bar assemblies do not connect to the A pillar area. In fact they do not even connect to the B pillar area. They are in the wrong locations in these vehicles to replace the torsional rigidity function of the rocker boxes.
Terry
Old 04-18-2020, 04:00 PM   #25
Killer Bee
Killer Bee's Avatar
Re: Blazer steps
thank you Terry, great explanation!
I'll have to keep this thread for sure
