03-28-2005, 03:58 PM | #1 |
will be swapping coils soon....
I will be swapping my coil springs soon and i was wondering what do i need to look foward to and what do i need to be careful of.. ( i have never taken out coils before) so i don't want one to smack me in the face and i become uglier than i already am... what is needed to do the swap or if anyone has a thread that covers this i would be interested. front and rear please... all i am doing is coils for now.. other components will come later...
Thanks in advance.. Rick
https://www.ebay.com/itm/295742064443 |
03-28-2005, 04:11 PM | #2 |
67 is sold
Some say no compressor needed, others say you do.
I prefer to take the safe route and rent a coil spring compressor, most places end up loaning them out for free |
03-28-2005, 04:42 PM | #3 |
For the fronts, I have compressors. If not, then chain them and lock the chain. If not, they can take off on you and REALLY change your looks. Seriously, they can get away and hurt you BAD. The rears, unbolt the shocks and pull them out.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
03-28-2005, 04:51 PM | #4 |
Member since 2000
compressors?!?!? for what?
I use to do suspension work and I never used a compressor on coil front ends. I did alot of trucks. if i had to get the job done I didn't even use a jack. Our trucks are cake, just put a jack on the the lower controlle arm brake off the lower ball joint, or which ever you like and slowly lower......done. |
03-28-2005, 06:17 PM | #5 | |
resident geek
71 C-10 stepper 88 Moostang T-Top w/ lots of goodies |
03-28-2005, 06:45 PM | #6 |
Member since 2000
good advice, I almost set the jack handle to angle out towards the front
03-28-2005, 07:57 PM | #7 |
Just did my sons front springs and they were a piece of cake. No compressor needed, Put the floor jack under the lower a-arm. Backed off both upper and lower ball joints about half way. Smack the side of the spindle where the ball joint is with a big hammer. Lower the floor jack real slow. It was that simple. Heck hardest part about doing the front end was trying to scrape off 30 years of oil and caked on dirt.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
03-28-2005, 10:59 PM | #8 |
OK, but I'll still use compressers or a chain. Wait till one gets away......
03-28-2005, 11:05 PM | #9 |
Got Light Emitting Diode?
i took some out of a cross member that wasnt on a truck. i was a bit scared of that, but i did the chain and lock thing, after it was all done i didnt even think i needed it. the springs didnt even move. but better safe than sorry
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
03-29-2005, 10:02 AM | #10 |
YA YA
I used the advise from Greasemonkey - "support the truck, stick a jack under the lower control arm shafts and unbolt the ubolts holding them on. Lower the jack and pull the spring out". I used an additional jack under the coil spring just to be on the safe side. Bolted the ubolts back in the exact place and was good to go.
Jimbo '72 SWB - 350 (frame-off resto in progress - donations accepted) '04 Chevy Avalanche '03 Cadillac CTS (wife's ride) Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707 |
03-29-2005, 10:40 AM | #11 |
67-72 Addict!
When you swap out front springs, how BAD is the front out of alignment?. I'm just curious what the truck feels like while driving it to the alignment shop afterwards. Thanks
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
03-29-2005, 10:49 AM | #12 |
YA YA
I just made sure that I put the ubolts back in the 'exact' same place and didn't feel any issues at all.
