05-19-2019, 07:49 PM | #1 |
suspension questions
My 87 Jimmy came with the quad shocks on the front, when i got to replace them can i just run with 2 ? And how will this affect the ride quality ? Whats a good shock to go with on a stock height truck ? lastly whats a good stabilizer shock to go with ? Truck is a daily driver that doesn't see any off road action. Is not lifted and if i do lift it at some point it will only be 2''
1987 Buick Grand National 2018 Road Glide Special |
05-20-2019, 12:19 AM | #2 |
Re: suspension questions
You can run a single shock in the outboard position. I am running the NAPA gas shock and whatever they had on the shelf for the steering
05-20-2019, 12:43 PM | #3 |
Ok thanks. Right now the truck has 4 Rancho RS6000 on it in the front and I’m thinking those can be improved.
05-21-2019, 01:29 PM | #4 |
Might also check out the Bilstein 5100's or the yellow Bilsteins.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
05-21-2019, 04:27 PM | #5 |
what type of ride should i expect from the yellow bilstein ? I went ahead and ordered some Monroe matics the other day, price was right and i wanted a stock type ride not anything too stiff but they can go back.
05-29-2019, 10:01 AM | #6 |
Sorry for delay....yellow should be close to stock, maybe better control.
I like my 5100's and handle the larger tires great. Very smooth compared to the Rancho's I pulled off. A better quality shock. If stock is what you are after, the yellows should be fine. I think they are 4300 or something like that.
