01-18-2020, 10:56 AM | #1 |
Old member
Grounds
Everyone knows you can never have enough grounds on a vehicle.
I'm working on my 68 step side and have added some grounds. Here is what I have so far. I have about 200' of this grounding strap that a friend gave me so I'm using it! As I go toward the rear I will be adding more to it right know I just have the cab on the frame. The ground strap in the first picture is connected to the heater box now with the stud in the bottom corner.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-18-2020, 12:02 PM | #2 |
Re: Grounds
Great job.
That will really help cut down on electrical issues. Did you use corrosion paste on the connections? I use something like this in the link below for dis-similar metals. Link: https://www.walmart.com/ip/BATTERY-D...15910c66063b7d .
01-18-2020, 06:53 PM | #3 | |
Old member
Re: Grounds
