Old 12-26-2019, 04:21 PM   #1
forestb
forestb's Avatar
Fuel line
What size of fuel line should I be using on my slightly modified carbureted 350 with an mechanical fuel pump and an under bed gas tank? I am planning on using aluminum fuel line
forestb is offline   Reply With Quote
Old 12-26-2019, 05:37 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Fuel line
3/8" is what I use...what size is your pickup tube?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-26-2019, 07:48 PM   #3
forestb
forestb's Avatar
Re: Fuel line
I’m not sure. It is a Jazz fuel cell. The fitting that comes out of the tube is an AN8 fitting so I am assuming that the pickup tube on the inside is also AN8
Old 12-26-2019, 09:20 PM   #4
mongocanfly
Post Whore
Re: Fuel line
in the -an size ive only used the -6an..which is about 3/8"
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-27-2019, 04:02 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Fuel line
6AN = 3/8"
My opinion is go with 3/8". I thought long and hard about a 5/16" line but there isn't much support for that in fittings etc. Besides in the future if you ever want to upgrade your set.
Old 12-28-2019, 07:49 PM   #6
forestb
forestb's Avatar
Re: Fuel line
Sounds like the 3/8 is the way to go. Can I use hard line all the way from the tank to the fuel pump? Or do I need to have a soft line hooked up to the pump to absorb the vibration of the motor?
Old 12-28-2019, 07:54 PM   #7
mongocanfly
Post Whore
Re: Fuel line
You dont have to use rubber...but I would just because...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-28-2019, 09:43 PM   #8
The Rocknrod
Moderator
Re: Fuel line
Yes use a short rubber piece.
Old 01-06-2020, 02:53 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Fuel line
You should have rubber (or some sort of flexible hose) that connects the hard fuel line on the frame to the fuel pump, and also from the tank to the hard fuel line attached to the frame too.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-21-2020, 05:11 PM   #10
forestb
forestb's Avatar
Re: Fuel line
If I use a 3/8 in stainless line what is the best way to connect a rubber fuel line to it?
Old 01-21-2020, 05:45 PM   #11
The Rocknrod
Moderator
Re: Fuel line
You could put a bubble flare at the end and get a stainless crimp clamp for the hose when you slide the hose on, It would look better.
Or you could get an 6AN push lock to 3/8" tube crimp fitting.
There are numerous ways. You could get wild and do compression to 6AN:
Old 01-23-2020, 05:55 PM   #12
LS short box
Re: Fuel line
You could replace your fuel pump with one that has NPT fitting and then you could run -6 all the way from the tank to the fuel pump. And then -6 up to the carb.
LS short box is offline   Reply With Quote
Old 01-23-2020, 06:08 PM   #13
forestb
forestb's Avatar
Re: Fuel line
That's what I have. I don't know if I want to spend that much money. I also would need to get line that will stand up against California Gas.
Old 01-27-2020, 07:28 PM   #14
forestb
forestb's Avatar
Re: Fuel line
I realized today that my holley fuel pump is leaking from one of its gaskets. What fuel pressure pump do you all recommend for a under the bed fuel tank?
Old 01-27-2020, 08:41 PM   #15
The Rocknrod
Moderator
Re: Fuel line
Thought you had a mechanical pump?
Old 01-27-2020, 09:14 PM   #16
forestb
forestb's Avatar
Re: Fuel line
It is
Old 01-27-2020, 09:22 PM   #17
forestb
forestb's Avatar
Re: Fuel line
I’m sorry I think I was looking at the free flow rate instead of the fuel pressure. Some of the pumps have different free flow rates so I was a little confused.
Old 01-27-2020, 09:35 PM   #18
forestb
forestb's Avatar
Re: Fuel line
Do I need to drain my oil in order to replace my fuel pump.
Old 01-28-2020, 08:40 AM   #19
The Rocknrod
Moderator
Re: Fuel line
No not at all.
http://67-72chevytrucks.com/vboard/s...&postcount=492
Old 01-28-2020, 06:00 PM   #20
LS short box
Re: Fuel line
Don't have to drain the oil. But as you pull the old pump out slip a small screw driver under the push rod to hold it up. Also its easier to install the new pump with the push rod all the way up so have someone bump the engine to rotate the cam.
