Old 12-16-2020, 01:15 PM   #1
Greasey Harley
Greasey Harley's Avatar
Part # for Disc/drum master cyl. with 1" bore?
I I just did a front disc conversion on my '68 c10 and really don't want power brakes.
Anybody happen to know a good part number for a Disc/Drum master with a 1.00" bore?
I have read that 71/72 c10s came Non-power disc/drum brakes, but I haven't come across a part number..
I can only find (and have installed) a 1.025' bore master. I have tried multiple parts houses. I can drive it, but the pedal is pretty darn stiff. I don't think the wife would like driving it much.
Not really into Brembo, Willwood or Corvette master cyls. If I can't find the correct one, I will probably have to convert to power, that would be a bummer.
Just want a stock looking, non power setup.
Somebody suggested a 1" bore master off a 1970 Nova, that part is available from Napa, I don't know if that will work though? anybody know if that's an option?
Thanks for any help.
-Russ
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 12-16-2020, 02:46 PM   #2
SIXTY9
Re: Part # for Disc/drum master cyl. with 1" bore?
I have a stock 72 non power M/C. When I get home this evening I will get you the part number off of it.
Wally
SIXTY9 is offline   Reply With Quote
Old 12-17-2020, 11:47 AM   #3
SCOTI
SCOTI's Avatar
I would think going to a smaller bore size will only increase the pressure @ the pedal (??).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-18-2020, 12:21 AM   #4
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
It's a trade off from what I've read and researched
. Smaller bore = more pressure but requres more pedal travel.. so if you dont have the travel no bueno.. all can change with pedal ratio but not likely anyone will go that route.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 12-19-2020, 08:27 PM   #5
Greasey Harley
I came up with this master cylinder, a Napa M1263.
It has the correct 1" bore, but it has a shallow detent, I understand this can be dangerous for manual brake applications.
I'm wondering if I can just pop it apart and drill the detent deeper.
Any reason not to do that? ( Obviously, it will void the warranty)
Ain't quite sure what to do here
-Russ
On the other hand, between the heavy clutch pedal and the big-bore manual brakes, every day is leg day
Old 12-20-2020, 03:37 AM   #6
54Caddy
GM Addicted
54Caddy's Avatar
Have a 68 as well and just did this setup. Disc front drum rear with a 1” bore.
eBay item #284107600469
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 12-20-2020, 10:28 AM   #7
blazer2007
won,t the aftermarket ones work like the little 8 inch or whatever they are or are you just trying to look stock ?
blazer2007 is offline   Reply With Quote
Old 12-20-2020, 04:18 PM   #8
Greasey Harley
Very much trying to look stockish (is that a word?) I ditched the shiny aluminum radiator because it didn't look like it came from 1968. I'm gonna modify the cheap Napa MC and see what happens.
It's just brakes, what's the worst that could happen?
...I keep going?
Old 12-20-2020, 05:01 PM   #9
SIXTY9
Sorry about being late with the pictures, Things came up. But here they are, The part number is 29881. I used this M/C on my 69 when I converted over to disc brakes on the front. It came off of a 72 with manual brakes, hope this helps.
Wally
Old 12-21-2020, 01:19 AM   #10
Greasey Harley
Originally Posted by SIXTY9 View Post
...The part number is 29881. I used this M/C on my 69 when I converted over to disc brakes on the front. It came off of a 72 with manual brakes, hope this helps.
Wally
That is some darn good information there, Wally. Thank you!
If I got a part number I can hunt one down.
Thanks for the assist
-Russ
