Old 09-07-2020, 08:00 PM   #1
Ptjsk
Gear Vendors Overdrive
After getting my Jimmy on the road, I was a bit concerned as to the drive-ability of the Truck.
I had rebuilt the motor, stroked it to a 383, and rebuilt both front and rear axles, as well as the 350 transmission.
Additionally, I installed Tru-trac posi units in both front and rear. Since I was going with 33" tires I thought 410 gear ratio would be the best.
After I finished I wasn't totally happy with trying to go 65 mph as the motor was rotating a bit above 3000 rpms.
I contemplated going with the overdrive transmission, but my transmission guy talked me into keeping the T350. He said they're just a great old (strong), transmission.
I began to look at the Gear Vendors for an overdrive unit. I probably had about a 50/50 response as to those saying it would work, and those saying it wouldn't work due to the short wheel-base.
Finally, I decided to take the plunge and just see for myself if it would work.
Then followed it up a Tom Woods driveline. These guys were super helpful and gave me guidance on rear end shims (6 degrees), and built a short driveline with a CV joint on the front end.
Happy to say, the Jimmy performs flawlessly! No vibration and most importantly, I can cruise along at 70-75 mph with no problems at all. The motors just cruising along now.
The only problem I have now is that I'll probably have to install one in the step-side!
Anybody have apprehensions with going this route need not worry. It will work!
Gear Vendors themselves are very helpful and can't say enough about Tom Woods drivelines!
Pat
Ptjsk is offline   Reply With Quote
