Old 08-01-2011, 09:06 PM   #1
warbucket
warbucket's Avatar
Bracing before I cut ?
I finally got the blazer in the garage, it's tight but the blazer runs so I can pull it out. I'm ready to start on the pass side floor and rocker box or whats left of the rocker box. Whats the best way to support the blazer before I start cutting? The top is still on, p.o used permatex to seal it. I'm trying to find a way to support it and still install the door for alignment. Any ideas or pics?
warbucket is offline   Reply With Quote
Old 08-04-2011, 07:03 AM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Bracing before I cut ?
leave the top on for support if you can... if not add as much bracing as possible... plus, install new body mounts and make sure everthig lines up first, then start replacing panels...
Rich
1972 K5 Blazer CST Click HERE
Old 08-04-2011, 09:10 AM   #3
turp mcspray
turp mcspray's Avatar
X2 on making sure the doors fit the boxsides and rockers BEFORE cutting anything loose.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 08-04-2011, 09:27 PM   #4
warbucket
warbucket's Avatar
Thanks for the help guys, I will leave the top on until the floors and boxes are done. Everything seems to line up well so I would like to weld in a 1" by 1" across the top of the inside door jam. I'll put a body mount kit on my list of think to look for at Carlisle Tomorrow.
Old 08-09-2011, 05:39 PM   #5
2003 silverado
2003 silverado's Avatar
LOOK at the blazer project 69 the new on and look what he did to the door area
!972 K5 Blazer,Highlander,A/C a twin to the one I Had
1972 K/5 Blazer CST Highlander 15YR project
2003 Silverado Crew 2500HD (Daily driver)
1997 Ford focus (Beater)
2003 ford Taurus (student)
2014 Ford Fusion HYB (wife)
2003 Jetta ( Student)
2003 silverado is offline   Reply With Quote
