Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 08-01-2014, 11:28 PM   #1
chefcorymac
Need Help Picking out an Amp.
I have a 1968 C-10 Truck and are running a custom autosound with 300 Watts Peak featuring 2 Channel RCA Auxiliary Input for Satellite etc, 4 Channel RCA Pre-outs and Subwoofer Line out w/Level and x-over Adjustments with (2) 6in Pioneer Speaker 120 watt speakers, Also, i'm running (2) 10" sub wooders, What amp would you recommend or would i run multiple ones. I've seen a lot of people recommending the Rocksford Fosgate Punch 300 series.
chefcorymac is offline   Reply With Quote
Old 08-02-2014, 12:07 AM   #2
Lattimer
Lattimer's Avatar
Re: Need Help Picking out an Amp.
Not a Rockford fan. Had issues with them years ago and never have gone back. Depending on how you have the subs wired, you can go with a 2 channel and a monoblock, or a 4-channel. 4-Channel can be operated in 3 or 4 channel mode depending, again, on how you have the subs wired.
To get the most out of the subs, you might be best with 2 amps. If the subs are 4 ohm single voice coils I'd wire them in parallel and use a monoblock amp. Then a more basic 2-channel for the mains.
Which amps you use are really a matter of budget and personal preference after you establish the required RMS for each set of speakers and how you want to wire the system.
I buy a lot of my stuff here: http://www.sonicelectronix.com/cat_i...mplifiers.html
I've personally had good luck with JL, Alpine, Kenwood, and Image Dynamics. Never had the $$$ to get into the higher end stuff though, so YMMV.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 08-02-2014, 11:04 AM   #3
jamesjones
Freakin Awesome!
jamesjones's Avatar
Without knowing the information on your subs, I would get one of these...
http://www.sonicelectronix.com/item_...PI-P900.4.html
Solid, reliable, cheap amp in a pretty small footprint that does rated power.
Run the front two channels to your 6s. Bridge the rear two to the two 10s.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 08-02-2014, 03:51 PM   #4
slowcpe
slowcpe's Avatar
I'm a fan of RF. I have the Prime 300x4 5-channel amp and it impresses me for an entry-level amp. I'm running it to Punch 4"s and 6x9s. Wanted the Punch equivalent but it was on back order through my distributor. They are pretty much my go to line when doing boat stereos.
For the money and size I've used the Massive Audio NX5 5-channel amp with great success. Sounds good, plenty of volume and very small.
I'm currently running a 5-channel Phoenix Gold in my boat and I couldn't be happier. Consider moving that to the Tahoe and going with 3 amps but it performs too good for size and amp draw. I bought thus a few years ago because I was a big PG fan back in the 90s and it hasn't disappointed.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
amp, radio, rockford fosgate
