03-25-2020, 09:10 AM | #1 |
4L80 / LS Swap no output reluctor
Just getting the last of the pieces together for the LS swap. I got the trans (4L80) today. It did not come with the input speed or output speed sensors, and did not come with the PRND module. I am getting this pieces ordered up, and there is no reluctor wheel on the output location. Do I need one?
03-25-2020, 11:11 AM | #2 |
Re: 4L80 / LS Swap no output reluctor
if no output ring on 4l80-e then its a 4wd trans or someone built the trans wrong .
sad part is the trans will need to be torn down to add this part inside . so if you SPECIFICALLY told them 2wd use and purchased a 2wd and then got a 4wd unit then call and let them know to make it right .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
