Old 03-28-2020, 03:01 PM   #26
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Plumbing for Ethanol
Here is an interesting document
https://www.google.com/url?sa=t&sour...=1585421961491
66 C20 Service Truck:
Old 05-29-2021, 12:19 PM   #27
LostMy65
LostMy65's Avatar
This thread has been focusing on the materials to use, but I have recently learned some more stuff about how to plumb for fuel with ethanol in it.
Many of you probably already know much of this, but it was new to me, and so I like keeping topics consolidated rather than having information scattered over several threads.
I've learned that even 10% ethanol fuel is more sensitive to heat than the fuel from the good ol days.
I'm seeing people running return lines for even carburetors. The goal is to try and keep the fuel from getting too hot - as it may be more likely to do in a 'dead-head' system.
When I plumbed for my Edelbrock, the recommendation was to get a fuel pressure regulator and keep the fuel pressure below 6psi.
I'm reading now that the regulator should be a bypass regulator that routes the excess fuel pushed from the pump back to the tank. Infact, some are saying to use a 12psi or higher fuel pump to keep the fuel moving faster through the system.
Plumb the bypass regulator as close to the carb as possible.
More to come...
Old 06-01-2021, 09:58 PM   #28
Captainfab
60-66 Nut
Thanks for the update.
Old 06-01-2021, 11:33 PM   #29
lutronjim
Interesting in lostmy65's post link https://www.google.com/url?sa=t&sour...=1585421961491 that PTFE and nylon are not listed.
lutronjim is offline   Reply With Quote
Old 06-02-2021, 10:32 AM   #30
LostMy65
LostMy65's Avatar
I can't get the link to open anymore.
But I think I remember it talked about how ethanol corroded or deteriorated certain materials.
Maybe nylon and PTFE aren't mentioned because they don't corrode or deteriorate with ethanol. But it is odd they weren't included.
Old 06-05-2021, 11:03 AM   #31
richards72chevy
richards72chevy's Avatar
More to come...
Would a cool can that cools the fuel before it goes into the carb work?
richards72chevy is offline   Reply With Quote
Old 06-05-2021, 11:28 AM   #32
LostMy65
LostMy65's Avatar
I saw mentions of that in my search.
Old 06-12-2021, 01:28 AM   #33
Greasey Harley
Greasey Harley's Avatar
...I've learned that even 10% ethanol fuel is more sensitive to heat than the fuel from the good ol days.
...I'm reading now that the regulator should be a bypass regulator that routes the excess fuel pushed from the pump back to the tank. Infact, some are saying to use a 12psi or higher fuel pump to keep the fuel moving faster through the system.
More to come...
I installed a WIX WIX 33040 Fuel Filter with a return line on my K10.
I don't know if it needed it but it was easy enough to install and only cost a few bucks.
That truck burns 91 octane 10% ethanol, it has a Q-Jet so it doesn't need a regulator.
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 08-08-2021, 12:19 PM   #34
vince1
I was going to go for a walk this morning and then I smell gas and see a stain on the pavement. The rubber line to the fuel pump decided to not hold fuel anymore. With the tank between the frame rails and pointing the truck uphill the dripping stopped.
It must have gotten eaten up by the ethanol and the line was not that old. Thanks for the link on what product to buy.
vince1 is offline   Reply With Quote
