Old 03-25-2020, 09:10 AM   #1
sara76
4L80 / LS Swap no output reluctor
Just getting the last of the pieces together for the LS swap. I got the trans (4L80) today. It did not come with the input speed or output speed sensors, and did not come with the PRND module. I am getting this pieces ordered up, and there is no reluctor wheel on the output location. Do I need one?
sara76 is offline   Reply With Quote
Old 03-25-2020, 11:11 AM   #2
sweetk30
sweetk30's Avatar
Re: 4L80 / LS Swap no output reluctor
if no output ring on 4l80-e then its a 4wd trans or someone built the trans wrong .
sad part is the trans will need to be torn down to add this part inside .
so if you SPECIFICALLY told them 2wd use and purchased a 2wd and then got a 4wd unit then call and let them know to make it right .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
