Old 04-05-2020, 08:35 PM   #1
chewychevy67
Oil Priming my 327. I Hear a gear noise
I primed my fresh 327 today. Dropped the distributor in and turned it by hand. Has good pressure. I can hear the gears from the pump with the distributor or if I use just a screw driver. It's a melling 10552 pump and melling shaft. Oil got to the lifters nicely as it should and that all looks good. Take a listen to this video and have a listen and let me know if this is normal please. The engine was already primed when this video was taken. Watch "Distributor noise 327" on YouTube
https://youtu.be/yxYskCEgSHA
chewychevy67 is online now   Reply With Quote
Old 04-05-2020, 09:38 PM   #2
Captainfab
60-66 Nut
Re: Oil Priming my 327. I Hear a gear noise
I am surprised you have that much oil pressure turning it that slow. Also how are you able to turn your distributor. It should be engaged with the cam gear.
Old 04-05-2020, 10:01 PM   #3
chewychevy67
I kind of thought that too. I have an end on the bottom of the distributor that has no gears on it so it only contacts the oil pump shaft. It's just for priming.
Old 04-05-2020, 10:24 PM   #4
chewychevy67
This is the oil I have in the engine.
Old 04-05-2020, 11:48 PM   #5
chewychevy67
I put another new melling high volume oil pump in a bucket of oil and turned it as well and it makes the same noise so can this really be the way they are? Watch "Melling oil pump" on YouTube
https://youtu.be/7pEh3NDXEiA
Old 04-06-2020, 01:30 PM   #6
cadillac_al
I'm stumped, I don't recall oil pumps making noise like that.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 04-09-2020, 05:07 PM   #7
dayj1
I'm not much help other than to say that I feel your pain. About a month ago, I was helping a friend prime his rebuilt 350 before startup (and luckily still on the engine stand) and it made exactly the same noise. We got a brand new melling pump and same noise. The third new pump that we tried was quiet. I read all kinds of stuff about the noise online with all sorts of opinions. From the folks who called melling, responses ranged from "It's OK" to "Turn it backwards. If it's quiet, then it's OK". But that makes zero sense to me. I wasn't about to run a pump that was that loud.
dayj1 is offline   Reply With Quote
Old 04-09-2020, 09:27 PM   #8
kaycee
kaycee's Avatar
Does it make that much noise with a drill attached to it to spin? Don't think I would be running it
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 04-09-2020, 09:37 PM   #9
chewychevy67
My drill is loud but I can hear it a bit. My engine builder told me he has run melling pumps with noise like this before and not had problems other than you can sometimes hear it. Funny thing is I have 2 brand new melling pumps that make the same noise. If I knew I didn't have to buy 5 more to get a quiet one I would but who knows.
Old 04-10-2020, 11:26 AM   #10
chewychevy67
I bought a new pump today. A melling with what they call "sharks teeth". It's supposed to run smoother. I'll update here when I get it installed.
Old 04-10-2020, 12:09 PM   #11
toolboxchev
I have heard of the new pumps with the re-designed teeth. They are supposed to be better is some aspect.
I have not heard of the gear noise issue, I would call Melling.
toolboxchev is offline   Reply With Quote
Old 04-15-2020, 07:19 PM   #12
kaycee
kaycee's Avatar
Did you find out anything on the noise?
2005 FXDWG stage3
63 IMPALA 327
Old 04-15-2020, 08:29 PM   #13
chewychevy67
I haven't got my new pump yet. I bought it online instead ov at a parts house. Once I get it I'll switch them and report back
Old 04-21-2020, 04:37 PM   #14
jbarron
I just put a new Melling in and it has the same gear noise.
Been running it and it is getting better.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
Old 04-21-2020, 07:27 PM   #15
chewychevy67
Can you hear it when the engine idles?
Old 04-22-2020, 04:13 PM   #16
jbarron
Not with the exhaust I have. Alternator whines more.
Old 04-23-2020, 01:20 AM   #17
chewychevy67
My new shark teeth style pump is here tomorrow. I want to see if it's as noisy as these straight cut gear ones are. If they are ill just leave the pump alone.
Old 04-23-2020, 04:41 PM   #18
chewychevy67
Got my shark tooth pump today. Same pump number I had before but it's the st type. I just set it in a can of fresh oil and spun it. Wow. Way quieter than the other. Looks like I'll be changing pumps tomorrow.
Old 04-24-2020, 08:01 PM   #19
AussieinNC
Moderator
AussieinNC's Avatar
All the Melling pumps I have installed in last 12 months needed to be clearanced internally....
There are a couple of areas internally that need to be ever so slightly touched up with a small die grinder....they then run quietly....
Shark tooth style dont need the same attention....so may be the best way to go in the future.
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
