08-30-2011, 01:54 PM | #1 |
What's this roll bar from
I bought this roll bar before I know what factory roll bars looked like for the 69-72 blazers. I'm not sure if this would be proper for my 71 or if it is for totally different year. looks to be factory built. what do you think?
1972 K5 Auto 4x4 factory air 2007 Silverado extended cab Z71 |
08-30-2011, 03:41 PM | #2 |
Re: What's this roll bar from
That, I believe, is a factory roll bar for '73 - '75. It will work, but in my opinion doesn't look right.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
08-30-2011, 09:04 PM | #3 |
I going to use the same one in my 72 but I'm going to remove the rear legs and bracket and make new ones to go higher on the bar and extend to the wheel well.
08-31-2011, 11:22 PM | #4 |
Don't think that there were "factory" roll bars for the 69-72's. Only aftermarket -but I could be wrong. Someone else will chip in. The most common 4 points that I have seen have the back legs bolting through the front slant of the wheel tubs.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
08-31-2011, 11:59 PM | #5 |
Your correct Grasshopper, should have said dealer installed.
