Old 03-14-2019, 04:34 PM   #1
Big70
6 lug vs 5 lug
So I have a 70 C 10 six lug four wheel drum Power. I was thinking about just converting the front to a disk with 2 1/2 inch drop spindles and 4 inch lowering springs in the rear and staying six lug. Should I look to get a late 70s early 80s pick up and pull all the running gear out and convert to five lug?
Big70 is offline   Reply With Quote
Old 03-14-2019, 05:02 PM   #2
nds1968
nds1968's Avatar
Re: 6 lug vs 5 lug
Drill your axles or buy new axles is an option also. I converted front and back to 5 lug because I would like to run torque thrust wheels some day.
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 03-16-2019, 03:22 AM   #3
Big70
Re: 6 lug vs 5 lug
I feel like just putting a disk brake conversion in the front would be the easiest and keeping it 6 lug....
Old 03-16-2019, 07:17 AM   #4
rjs53
Re: 6 lug vs 5 lug
I did the 6 to 5 lug because of wheel selection. Then started looking and found a lot of nice wheels for 6 lug. If I had to do it again I would have just put disc on.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 03-16-2019, 09:27 AM   #5
uncle
Re: 6 lug vs 5 lug
Most 70 rear axles are wide enough so that you can put the five lug axles from a 71 through 81 12 bolt truck in them. The easiest way to tell is measure from backing plate to backing plate and it should be around 57 inches.
uncle is offline   Reply With Quote
