Old 09-21-2019, 11:54 AM   #1
75C10
How do I lower a K5 2 wd
There doesn't seem to be a kit available to lower the rear of a 1977 2 wheel drive K5 4". What problems do you encounter with a C10 shackle hanger kit? Can it be made to work? Is there another way short of a flip kit and then raising it slightly with a 4X4 hanger. Dearching and/or removing leaves? Any feedback is appreciated. Thanks
75C10 is offline   Reply With Quote
Old 09-23-2019, 11:14 PM   #2
75C10
Re: How do I lower a K5 2 wd
Didn’t realize I asked such a difficult question.
Old 09-24-2019, 07:37 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Pulling leaf springs will give you wheel hop.
I've done dropped leaf springs and a longer rear shackle, but that gets into re-routing the fuel filler hose.
I like the flip kit and 4x4 rear hanger method.
That gives the best stance, but you will need to c-notch the frame.
Aftermarket 4-link is another option.
Keith
Convert to disc brakes.
Old 09-24-2019, 11:56 AM   #4
75C10
Thank you Keith
Old 09-24-2019, 12:03 PM   #5
75C10
Is the c notch for blazer the same as the c10?
Old 09-24-2019, 12:51 PM   #6
lolife99
lolife99's Avatar
I believe they are different.
Crown Suspension sells a "blazer specific" notch.
I'm sure there are a few other companies that do also.
https://www.ebay.com/itm/Crown-Suspe...-/181848752516
Keith
Old 09-24-2019, 12:56 PM   #7
75C10
I looked on lmc and there wasn’t one for blazer. Thanks for your help.
Old 10-11-2019, 01:42 PM   #8
phillipm
I used these on my '78 and they worked great. Definitely different than the c10 versions.
Old 10-11-2019, 10:16 PM   #9
flashed
Check out United By Trucks on YouTube , 2 wheel drive Blazer Chassis . One of our newer videos . More to come .
flashed is offline   Reply With Quote
Old 10-13-2019, 02:20 PM   #10
Willowrun
Willowrun's Avatar
Here’s how I lowered mine. No notch and it’s never bottomed on the frame.
http://67-72chevytrucks.com/vboard/s...d+to+buy+%9177
