09-21-2019, 12:24 PM | #1 |
neutral safety switch question
So im finishing up my 6.0 LQ9 swap with 4L80E. Need help with the ignition switch on which terminals to use to wire the neutral safety switch.
-Lokar floor shifter has neutral safety switch built i. -Generic ignition switch -Ron Francis wire harness pictures attached. Any help would be appreciated. Thank you in advanced.
Bagged 1959 GMC 1969 C-30 dump My 59 build. http://67-72chevytrucks.com/vboard/s...d.php?t=592878 |
09-26-2019, 10:10 AM | #2 |
Re: neutral safety switch question
The sol term will go to the neutral switch & the other term. on the neutral switch goes to the starter selinoid.
George |
09-26-2019, 04:00 PM | #3 |
Thank you that’s what I was thinking was correct
