Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 08-13-2019, 08:44 AM   #26
JoeKan
JoeKan's Avatar
Re: 2 quick questions about rust
Yes, that is it. So epoxy primer is different from regular primer?
JoeKan is offline   Reply With Quote
Old 08-13-2019, 11:08 AM   #27
mongocanfly
Post Whore
mongocanfly's Avatar
yes ...if you have bare metal it needs epoxy primer on it...then you can do the body work
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-14-2019, 05:39 PM   #28
JoeKan
JoeKan's Avatar
Bare metal like in my picture or do I have to sand some more?
Old 08-14-2019, 11:36 PM   #29
mongocanfly
Post Whore
In that last pic..is that rust between the red lines?...or red primer?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-15-2019, 07:31 AM   #30
nsb29
nsb29's Avatar
I went back and looked at your previous statement yes you can put the epoxy primer over what’s left of the old primer. A DA would probably be a little faster but they also use a lot of air don’t know how big your compressor is. Another idea you may try, if you have a heat gun heat the paint to soften it up and then use a razor blade scraper you can takeoff a lot of paint in a short period of time won’t work everywhere but great for big flat areas, then come back over it with your sander.
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 08-17-2019, 09:14 PM   #31
JoeKan
JoeKan's Avatar
Originally Posted by toolboxchev View Post
I bought some Kleen Blast. Look um up. Copper Mine Slag, got my cheapo sand blaster running right. That stuff will cut!
Leaves a perfect Mohs Scale finish which is exactly right for epoxy.
Is this something you did yourself? I'm seeing on some places you use a power washer
Old 08-20-2019, 01:10 PM   #32
toolboxchev
Having gone full in, I would get a DA. Get all that old primer off the vehicle. You will know for sure you have a bond with all areas.
Body work is about tools. Big air compressors for time effective production. I am no body or paint guy yet I have figured this out.
When good enough is not perfect, and perfect is not good enough will be the question. Check out the forums on Southern Polyurethanes those guys will give you good direction. Remember above all, the Owner, Barry would be the guy to listen too above everyone else. You will find tricks along the way.
As far as rust goes, if its there, sand and wire wheel it out. Going over it multiple times is the key. The least amount of it that cannot be gotten rid of is the best. Those tiny cracks and crevices are for the blaster. What ever media you use.
toolboxchev is offline   Reply With Quote
Old 08-20-2019, 01:19 PM   #33
toolboxchev
Yes. Take a look at this repair both before and after. I am not sure where you get I am using a power washer??? I did blast, then sand, wire wheel more than 5 times over and over again.
As close as you can get to clean metal. On a side note Ospho was used, Only as Barry prescribed.
I actually did not have a pic in between the 3rd and 4th pic. I had gone over approximately two more times to remove more of that rust and got it even cleaner before the coat of epoxy. This should explain the process a bit more in detail for you.
Old 08-20-2019, 05:00 PM   #34
JoeKan
JoeKan's Avatar
Wow, toolboxchev, thanks so much. A picture(s) is indeed worth a 1000 words! How you did yours is what I'm going to be aiming for. I talked to a company today that does some sort of "bead" blasting and he wants my truck to be taken apart and delivered to him that way he can do each piece individually and then have better control over it warping. I'm thinking I can take of the hood, 2 door, 2 front fenders and the tailgate. He charges $100 per hour. This way, I would have a lot of my time freed up.
I have no idea what I meant when I said your power washed your truck??
Old 08-20-2019, 08:14 PM   #35
mongocanfly
Post Whore
Joe ,you may have been thinking of the pressure washer/sandblasting setup...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-21-2019, 07:07 PM   #36
toolboxchev
That would be the dustless blasting setup.
Old 08-21-2019, 10:03 PM   #37
mongocanfly
Post Whore
Yes, that's one...but I was referring to the attachment you can get to sandblast with your pressurewasher... dont know how good it works,but it exists
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-21-2019, 10:51 PM   #38
JoeKan
JoeKan's Avatar
Is this the one you're talking about? Do you think it will work and what would be the chances of warping the metal?
https://sanaeng.com/products/high-pr...RBVvGNYSeaZ2wQ
Old 08-21-2019, 11:19 PM   #39
mongocanfly
Post Whore
That what I assumed your were talking bout....I have no experience with it....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-21-2019, 11:27 PM   #40
JoeKan
JoeKan's Avatar
I just found that tonight and thought I would get your input on it. But I need to call the guy back about doing the blasting and find out more about what/how he does his. When I talked to him the other day on the phone, he sounded really rushed so I was hesitant in carrying out a long conversation.
Old 08-21-2019, 11:29 PM   #41
JoeKan
JoeKan's Avatar
Here's his web page:
http://www.baremetalkc.com/services/
Old 08-21-2019, 11:32 PM   #42
mongocanfly
Post Whore
I'll just throw this out there...you'll be time and money ahead letting a pro do it...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-22-2019, 07:54 AM   #43
nsb29
nsb29's Avatar
I like the part where it says powder coating has corrosion resistant properties not available with other products that’s a joke
Old 08-22-2019, 07:11 PM   #44
JoeKan
JoeKan's Avatar
I agree 100% with that statement!
