Old 09-18-2003, 06:09 PM   #1
TODDS 72
Not the nightly winner
TODDS 72's Avatar
hei wiring
hey guys need a little help,going from points to hei on my 250 i6,need to know what to run for wiring and from where.
thought i had a diagram saved but can't find it ,i know this has been on the boards before.
Thanks Todd
72C10SWB BLUE 350/350
86K10LWB BLUE 5.7 700r4 7.5' fisher plow
93S10XCAB4X4 BLUE 4.3 4L60e
69gmc c10 v8 3 on the tree yellow 72k10 swb 350 3 on the tree green
86k15 swb5.0L 4spd brown
TODDS 72 is offline   Reply With Quote
Old 09-18-2003, 10:41 PM   #2
TODDS 72
TODDS 72's Avatar
ttt......anybody?
Old 09-18-2003, 10:59 PM   #3
Hotrodhenryj
Truck Farmer
Hotrodhenryj's Avatar
All you need is a hot lead from the ignition to fire the HEI. Should be able to use the + lead from your stock coil.
Arizona rust free sheetmetal
Hotrodhenryj is offline   Reply With Quote
Old 09-18-2003, 11:58 PM   #4
Orion 762
This attached image may help. I found it here a few days back.
A "key" feature is getting the "pink" 12 gage wire directly to your new distributor. You can also completely remove the "yellow wire" going to your starter solenoid (on the starter for my '71 Cheyenne).
I believe that others have had problems using the old "+" lead to your coil, because the these leads were intentionally made "resistive" to reduce voltage to the coil (to around 7 volts or so). The new HEI needs the full 12 volts.
Orion 762
Orion 762 is offline   Reply With Quote
Old 09-19-2003, 12:31 AM   #5
oldtrucknut
67-72 truck surgeon
Yes, Orion is right that the stock coil wire will not supply full power that the HEI needs. I ran a wire from the "ignition unfused" terminal on the fuse block to the distributer. It works fine.
1969 Chevy C10
1993 Toyota Camry LE
1999 Ford F250 Super Duty 4x4 diesel
2008 Dodge Charger Super Bee
1953 International R182
oldtrucknut is offline   Reply With Quote
Old 09-19-2003, 06:50 AM   #6
TODDS 72
TODDS 72's Avatar
thanks guys,that diagram was the one i was lookin for..
Old 09-19-2003, 08:55 AM   #7
biglou55
todd72 biglou55 right down the bottom of the hill from you in greenfield I have a set of instructions for hei conversion that i got off one of the boards it is quite detailed if you would like a copy call me at work 7751607 I have voice mail or at home 772-6660 ask for lou senior. I am glad to have another 67-72 historian < ha-ha> around.
Certifiably crazy person
biglou55 is offline   Reply With Quote
Old 09-19-2003, 05:34 PM   #8
TODDS 72
TODDS 72's Avatar
hey lou,,,,i think we have met before you stopped at my shop and wanted to buy my truck from me,bout a year or more ago,if your the lou with the small egine repair.if not its nice to meet someone local.
Old 09-19-2003, 08:28 PM   #9
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
biglou55 is it possible for you to fax a copy or mail a copy of the instuctions? Let me know I can PM you with the number or address.
-Ron-
OldSkool71 is offline   Reply With Quote
Old 09-22-2003, 09:54 AM   #10
biglou55
todd72 that,s me with the repair biz. I thought your garage was in buckland or am I confusing you with someone else. oldskool 71 I will be glad to mail you a copy or fax one if i can use the fax at work. hale@gcc.mass.edu
