09-19-2003, 04:55 PM | #1 |
Replacing inner fenders
Is it possible to replace inner fenders without pulling the fenders off? Or do I need to pull off the fenders?
Thanks, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
09-19-2003, 05:00 PM | #2 |
COMING SOON...
Just took mine off yesterday...fenders on. It takes some bending, but you can eventually take them out through the wheelwell intact.
09-19-2003, 05:01 PM | #3 |
NAW YOU DON'T HAVE TO PULL OFF YOUR FENDERS TO REPLACE YOUR INNERS. IT IS ALOT EASIER TO DO WITH YOUR TIRES REMOVED THOUGH.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
09-19-2003, 05:02 PM | #4 |
Thanks Theo, I was hoping that was the case. Uhh, do you think they'll bend back in??
Rg
09-19-2003, 05:08 PM | #5 | |
COMING SOON...
09-19-2003, 05:34 PM | #6 |
RAGGEDJIM -- I'VE PROBABLY REPLACED AT LEAST 30 INNERS & HAVE NEVER DONE ANY WITHOUT THE FENDERS IN PLACE.
09-19-2003, 07:44 PM | #7 |
I second the removing tire Method.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
09-19-2003, 09:16 PM | #8 |
Easy to do even with the wheels on in a confined garage, But would be much easier with wheels off. Not a problem GO FOR IT
John Sacramento Area 1969 C10 Fleetside |
09-19-2003, 09:29 PM | #9 |
Easy to pull off, even more fun to put back on, lol.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
09-21-2003, 09:28 PM | #10 |
Thanks for the replies, I plan to do it when I get the new inners in the mail.
Rg
