Old 09-05-2020, 12:05 PM   #276
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: '72 Cheyenne K10
Sounds good
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 09-06-2020, 08:05 PM   #277
jimbosprint
jimbosprint's Avatar
I probably added 15-20 hp by shining up the chrome air cleaner.
jimbosprint is offline   Reply With Quote
Old 09-06-2020, 10:38 PM   #278
Ol Blue K20
Dang it.... that's what I've been doing wrong!!!!!
Dale
Old 09-14-2020, 05:35 PM   #279
jimbosprint
I like the easy stuff like replacing a mirror. (a lot easier with no door panels )
Old 09-14-2020, 09:23 PM   #280
jimbosprint
More easy stuff...
Old 09-15-2020, 07:45 AM   #281
Ol Blue K20
Easy is always good. Progress is always good.
Dale
Old 09-17-2020, 07:39 PM   #282
jimbosprint
Today I fixed something that has been bugging me for months - the brake lights kept getting stuck on. I got in a habit of pulling the pedal up with my other foot, but one night I forgot and drained the battery. The switch bracket was bent, the threads on the switch were messed up, and the pedal was adjusted past where the spring would return. I bent the bracket back, got a new switch, pedal adjustment, and problem solved!
Old 09-19-2020, 05:59 PM   #283
jimbosprint
The center console I built was too tall, so I cut it down a few inches. I like this better.
In other news, the brake lights still get stuck on. It happens after driving, but I cannot make it happen in my driveway. This is a very annoying problem.
Old 09-24-2020, 10:41 PM   #284
jimbosprint
Brake lights sticking on - the rod that goes into the booster does not release when driving. If I pull the check valve on the booster it still does not release. The return spring is strong. I can't see anything binding or rubbing in the linkage. I cannot duplicate the issue in my driveway even with the engine running. Any thoughts?
Old 09-25-2020, 08:43 AM   #285
Ol Blue K20
No clue, my only suggestion is to lube all pivot points. My 97 has a strange similar problem. I noticed it last night. The trucks park haven't driven it in hours. I looked out and the brake lights or on then off then on and off. I disconnected the battery so I could sleep.
Dale
Old 09-26-2020, 11:31 AM   #286
jimbosprint
I don't know where the old useless mirror came from, but it was barely hanging on. My new passenger convex mirror arrived yesterday. What a nice improvement.
Old 09-26-2020, 12:16 PM   #287
Ol Blue K20
Nice, where did you order it from?
Dale
Old 09-26-2020, 12:52 PM   #288
jimbosprint
LMC, about $40. It was backordered when I got the driver side. I read that the regular flat passenger side mirrors are not good for much more than plugging the holes in the door.
Old 09-26-2020, 01:42 PM   #289
Ol Blue K20
It sure looks good.
Dale
Old 10-02-2020, 11:16 PM   #290
jimbosprint
My truck died on me five or six times today in line at the dump, and ran like garbage all the way home. It would barely idle, and was really rough trying to accelerate. Temp and oil gauges were reading fine. For some reason I suspect the torque converter, but that could be totally wrong. I'll look at it closer in the morning.
Old 10-03-2020, 06:45 AM   #291
Ol Blue K20
Attachment 2052608
Don't feel bad, Blue vapor locked at the dump. It was 105* and the gauges read fine. I had to wait an hour for it to start. Maybe yours was trying to vapor lock.
Dale
Old 10-03-2020, 12:04 PM   #292
SRU1436
I’m thinking vapor lock too.
SRU1436 is offline   Reply With Quote
Old 10-03-2020, 07:56 PM   #293
jimbosprint
It was my understanding that the return fuel line (which this truck has) prevented vapor lock. Maybe my fuel pump is bad? I drove it around the block and it ran a little rough but didn't die. I have a suspicion that I messed something up when I replaced the exhaust manifolds. I should pull the spark plugs but it is too hot and smoky out to work on it now.
Old 10-04-2020, 02:23 AM   #294
SRU1436
How close are your fuel lines to the exhaust or any other area that generates a ton of heat? What was the weather like and what kind of driving were you doing, were you idling A long time?
Old 10-04-2020, 01:07 PM   #295
jimbosprint
Yes, I was idling for a long time waiting in line. It might be the new metal fuel feed & filter running too close to the intake under the carburetor.
I'm thinking a 1" phenolic 4-hole carb spacer would help, and/or replace that feed line with rubber hose.
Old 10-13-2020, 07:45 PM   #296
jimbosprint
Work day up at the disc golf course.
Old 10-17-2020, 03:09 PM   #297
jimbosprint
I tossed a 1" phenolic carburetor spacer on. I hope it solves the vapor lock issue.
Old 10-18-2020, 07:03 AM   #298
Ol Blue K20
Keep us posted on how it works.
Dale
Old 11-03-2020, 06:45 PM   #299
jimbosprint
Somehow my front driveline is bent. I have not used the 4wd except a trip around the neighborhood (where I immediately noticed a shake). Maybe I just didn't notice when I took it in, but I would be surprised if the shop I paid would put new U-joints in a bent driveline. I did not replace the cardan joint at the same time (and probably should have). This driveline was also about 3/4" longer than the other one that was on the truck when I got it.
Old 11-04-2020, 09:31 AM   #300
Ol Blue K20
That's not good.
Dale
ochre
