![]() Join Date: Jan 2013
WTB SBC Engine Parts
Looking for a set of original 71-72 350 valve covers. Pass side must have grommet for qjet carb spacer hose fitting. Driver side w/ pcv on front & push in oil cap on rear. Also looking for qjet spacer stack with hose & original coil mounting bracket & bolts.
Re: WTB SBC Engine Parts
Hi, I have a set of 72 350 original valve covers, I will post a few pictures in about 5 min Thanks Dwayne
https://www.paypal.me/Dwayne77 |
Here is pics of the valve covers and coil bracket and bolts
That's weird an oil fill on both of them. How bent up are all of the spark plug wire looms? Are the engine lifting brackets on the intake manifold?
Are all the following items available on this engine:
Distributor & hold down bracket spark plug wire looms engine lift brackets heat shields Also did this engine come with a qjet carb? |
Lifting brackets look good, L and R rear looms look good, L and R front looms look good, not sure how many looms on on the original 350. pics included
last pic
I have the dist and hold down bracket( not sure if the dist is any good the truck has been setting for about 10 years) yes has the original Q Jet ( butter flyies open but tight) needs rebuilt
should be 6 looms total...2 on back of intake...2 on bellhousing mounting surface...& 1 on ea. side under the front heat shield. if all there get me prices on those, all the heat shields, lifting brackets, valve covers, coil bracket & bolts, & distributor. I'm also looking for a divorced choke setup for a qjet carb...choke thermostat & screw, cover & rod. Whatever you have give me prices & shipping. My zip is 22630 Jamie
if truck was an auto give me a price on the carb. Do you have the hard fuel line that goes from the pump to the carb?
Truck was manual, I know I have 5 of the wire looms, I have the hard fuel line, looks good not sure it is original. I will remove everything tomorrow and get picks of all the stuff you want and give you a price. Thanks Dwayne
Dwayne: I've enclosed a pic of how the factory plug wire routing is. I almost forgot that there's a small loom that bolts to each side of the oil pan rail. Anyhow get what you can and your plan sounds good. I'm working today then I'll be off till Monday.
#13 |
![]() Join Date: Dec 2016
Oddfire, I should have the carb spacer, if you need one.
#14 |
Here is a pic of everything you wanted and break down
L and R Valve Covers-$25.00 Dist and hold down W/bolt $15.00 Coil Bracket and Bolts- $10.00 3- Heat Shields,LF,LR,RF(RR was missing)-$10.00 5- Wire Looms, L and R Rears,L rear top,L and R Front under Heat Shields-$10.00 2-Lift Brackets-$10.00 Divorce Choke(spring looks good),cover,choke rod, screw-$10.00 The picture has the hard fuel line but I am going to keep it right now,I need to make up a fuel line for my truck. When I get done I can pm and see if you are still interested. If you want everything the shipping cost would be $17.90, I could do every thing for $105.00 Shipped Thanks Dwayne I posted a picture of the carb 1st pic, 2nd pic of my carb on my truck which is a turbo 350 auto, looks like the same throttle lever. Carb $10.00 plus shipping. Also there is a pic of the air cleaner, carb stack spacer w/hose,heat riser and tube. Looking to sell everything for $100.00 Thanks Dwayne
#15 |
Hey Old School, sorry for my reply about the carb spacer. I didnt see that you had one listed. Cant stand it when someone tries to hijack another member's sale. Not my intentions.
#16 |
Dwayne: All parts look good from what I see. How bout $200 even for everything shipped inc. the fuel line when you're finished? Jamie
#17 |
Hi Jamie, I would do $210.00 shipped Thanks Dwayne
#18 |
Sounds good! Is that your paypal at the bottom?
#19 |
Yes. that is my paypal.
#20 |
Jens Jimmy- No problems here.
#21 |
It's amazing what a blasting cabinet & some black paint will do to old nasty ugly parts! Can't wait to do the valve covers...
