Old 10-11-2020, 12:33 PM   #1
richards72chevy
richards72chevy's Avatar
Fan clutch tightening
Replacing the water pump and fan clutch on my 02 silverado.Im having hell judging how tight the nut is attaching it to the waster pump.I had a thick piece of copper wire going into the pulley and wrapped around an alternator bolt and it snapped it.From what I have read this nut is unlikely to loosen it's self.Is this true?I know the old one wasn't too terribly hard to remove.IMG_20201011_112008.jpg
richards72chevy is offline   Reply With Quote
Old 10-11-2020, 12:51 PM   #2
truckdude239
truckdude239's Avatar
Re: Fan clutch tightening
They tight them selfs when spinning
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 10-11-2020, 02:19 PM   #3
richards72chevy
Thank you.I just wanted to confirm .I trust you guys more than other websites.
Old 10-12-2020, 04:38 PM   #4
BlouDon
BlouDon's Avatar
On a petrol engine, they do not have to be tightened much.
The issue comes in when the engine is switched off. The compression of a petrol engine is low compared to a diesel engine and therefore, when switching a petrol engine off, it takes "much" longer to come to standstill than a diesel engine - which decelerates to standstill much more rapidly (due to its high compression) than a petrol engine and thus the inertia of the spinning fan clutch could undo itself.
That's why the risk of the risk of the fan clutch undoing itself is more of an issue on diesel engines where they must be tightened well.
Best regards, Philip
Chev: '70 C10 (350 V8 / 700R4 ) & '59 Apache ( 235, 3-sp )
Jensen Interceptor '74: Mopar 440(EFI'ed) / 4L60e
Jaguar: '72 E-type Coupe V12 & '74 E-type V12 Convertible & '80 XJS V12
BlouDon is offline   Reply With Quote
