01-30-2022, 05:48 PM | #101 |
Re: Somewhat useless Truck trivia...
The stamping I'm referring to can be found in the inside lower driver side corner (with reference to the tailgate installed and closed). There are two tailgates pictured below. Both are OEM 1972 chevy tailgates. One appears to have the number "34" stamped on it, and the other has "40."
01-30-2022, 05:51 PM | #102 |
And here is a gmc tailgate that is similar but a little different. This one has a rectangle stamped into the tailgate with "37" stamped inside the rectangle.
02-27-2022, 01:21 PM | #103 |
The shot callers or head honchos at GMC.
03-03-2022, 08:38 AM | #104 | |
4wd Enthusiast
https://www.facebook.com/groups/1536...75249199436281 Does it look like the SPID has been tampered with? The call out on the front locking hubs looks to have been painted over and restamped and the model on the SPID starts with a CK and not a KE. You might need to join the group to see the post on FB.
*1972 Cheyenne Super SWB K10 Original Paint 350/350 AC (Added) Tach/Tilt *1972 Cheyenne Super SWB K10-Buckets/Tach/Tilt/Wood Bed/Manual Throttle/Marker Lamps *1972 Cheyenne Super Custom Camper K20 AC/Tilt/Aux Tank/Aux Battery/Wood Bed *1970 Olds 442 W-30 M-21 4-speed *1978 Ford F250 4x4 Ranger-Explorer-Camper Special Marti Report: 1 of 1 *1986 K30 Silverado Crew Cab 502/TH400 *2002 Silverado LT 2500 Duramax Long bed Crew Cab 4x4 107K original miles *2022 RAM Bighorn 1500 Waldoch edition ...Daily Driver |
03-03-2022, 08:52 AM | #105 | |
6>8 Plugless........
I see where someone said he couldn't find the correct parts because his truck has the wrong rear end. Not according to the spid. It should have a D60 since it has G87 listed.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 03-03-2022 at 09:00 AM. |
03-03-2022, 09:11 AM | #106 | |
4wd Enthusiast
*1972 Cheyenne Super SWB K10 Original Paint 350/350 AC (Added) Tach/Tilt *1972 Cheyenne Super SWB K10-Buckets/Tach/Tilt/Wood Bed/Manual Throttle/Marker Lamps *1972 Cheyenne Super Custom Camper K20 AC/Tilt/Aux Tank/Aux Battery/Wood Bed *1970 Olds 442 W-30 M-21 4-speed *1978 Ford F250 4x4 Ranger-Explorer-Camper Special Marti Report: 1 of 1 *1986 K30 Silverado Crew Cab 502/TH400 *2002 Silverado LT 2500 Duramax Long bed Crew Cab 4x4 107K original miles *2022 RAM Bighorn 1500 Waldoch edition ...Daily Driver Last edited by pryorstemmed; 03-03-2022 at 09:18 AM. |
03-03-2022, 09:26 AM | #107 | |
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
03-03-2022, 09:46 AM | #108 | |
4wd Enthusiast
03-03-2022, 12:09 PM | #109 |
More trivia:
Martin Caserio came up through Pontiac Motor Division, taking John DeLorean's place when DeLorean moved to Chevrolet. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-11-2022, 08:22 PM | #110 |
Early '69 3/4 ton cap ( 12" diameter ) with a shallow concave center cone. Later 69-72 3/4 ton caps had a higher convex center cone
04-20-2022, 05:06 PM | #111 |
Useless trivia:
Know how many GM part numbers are the lower number (odd) is for the LH side and the higher number (even) is for the RH side? Well the door lock lever stamps are almost close. The LH is stamped P833475 & the RH is P833474, just to add some confusion to my day. Sure those aren't GM part numbers, perhaps, but they're original.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
