Old 11-13-2019, 05:50 AM   #1
tino0217
Edelbrock electric choke broken?
600 series carb. Previous owner didn't hae it hooked up. I loosen the screws but it doesn't seem to move the carburetor flap, so nothing happens on a cold star. It's hot but no action. Any advice?
tino0217 is offline   Reply With Quote
Old 11-13-2019, 09:14 AM   #2
geezer#99
geezer#99's Avatar
Re: Edelbrock electric choke broken?
Are you holding the throttle open while turning the cap?
Are you turning the cap both directions to test for choke blade movement?
Old 11-13-2019, 01:49 PM   #3
tino0217
the choke blade is always open no movement only by touch. i haven't tried holding the throttle open but someone also suggested taking off the choke plate and check for movement.
Old 11-13-2019, 02:33 PM   #4
HO455
HO455's Avatar
Can you post a fairly close up photo of each side of the carburetor? The PO may have bent something or added some thing to hold the choke open.
RIP Bob Parks.
Old 11-13-2019, 03:05 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
First thing I would do is remove the cap and see if the coil spring is engaging the lever correctly inside the choke housing. If the lever is on the wrong side of the tang on the spring it won't work.
LockDoc
Leon
Old 11-13-2019, 03:09 PM   #6
geezer#99
geezer#99's Avatar
LockDoc
No need to remove the cap unless needed.
Holding the throttle open and turning the cap both ways will tell you right away if the connection inside is good or not.
Old 11-13-2019, 03:27 PM   #7
HO455
HO455's Avatar
RIP Bob Parks.
Old 11-14-2019, 12:59 PM   #8
68 P.O.S.
LockDoc
This^^
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 11-14-2019, 01:13 PM   #9
demian5
demian5's Avatar
LockDoc
Yes and that the throttle needs to be held slightly open as well when turning the choke coil housing, otherwise the idle screw holds it in one place.
Food for thought, I had a friend with a 70 camaro, someone put a holley on with electric choke. They simply ran a wire from the coil + (still a points car) to the choke, choke never worked right, would run great cold but never come off the choke, like it was stuck.
It was only getting 6v (resistor wire for voltage to coil).
I ran a new wire from the fuse block to the choke and it worked great with 12v.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 11-14-2019, 01:42 PM   #10
tino0217
brother, that's what it was. took it apart shot some silicone lubricant startedit this morning and ran like champ. thanks and GOD bless
Old 11-14-2019, 01:45 PM   #11
tino0217
the coil inside was disconnected. thanks for quick response
Old 11-14-2019, 10:18 PM   #12
LockDoc
LockDoc's Avatar
Good deal. Glad you got it starting good.
LockDoc
Leon
Old 11-15-2019, 05:47 AM   #13
tino0217
Turns out I had to open up the choke and found that the spring inside was not connected correctly once I did that they worked fine the next morning
