Old 04-14-2021, 08:54 PM   #1
Hotcorner
Hotcorner's Avatar
Pertronix Advance
Can someone help me with a question for a Pertronix distributor? With a 350 with an RV cam, where should I start as far as springs and advance limiters? Should I lock out mechanical advance and rely on vacuum advance?
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Hotcorner is offline   Reply With Quote
Old 04-14-2021, 09:53 PM   #2
geezer#99
geezer#99's Avatar
Re: Pertronix Advance
It depends on your set up.
A stock versus modified thing.
Stock motor might like a lazy timing curve and a modded motor might like something more aggressive.
What motor, cam, heads, intake, carb, trans, rear gear ratio all play a part.
How is yours set up?
Old 04-14-2021, 10:16 PM   #3
Hotcorner
Hotcorner's Avatar
Stock motor with Edelbrock intake and carb. Believe it’s an RV cam. SM465 trans. 3:73 gears an 33” tires. Loves to pull from low RPMS
1969 GMC K25
Old 04-14-2021, 10:19 PM   #4
geezer#99
geezer#99's Avatar
What’s your initial timing set at?
That’s the best place to start.
Old 04-14-2021, 10:44 PM   #5
Hotcorner
Hotcorner's Avatar
It likes 13 deg btdc
1969 GMC K25
Old 04-14-2021, 10:50 PM   #6
geezer#99
geezer#99's Avatar
Is your pertronix completely adjustable?
Usually you want total timing (mechanical+initial) to be near 32 degrees all in by 3200 rpm.
With your 13 you’ll want about 20 mechanical.
Old 04-14-2021, 10:54 PM   #7
Hotcorner
Hotcorner's Avatar
Yes. Different springs and limiters came with it.
1969 GMC K25
Old 04-14-2021, 10:58 PM   #8
Wrenchbender Ret
Do not block off the mechanical advance.
George
Wrenchbender Ret is offline   Reply With Quote
Old 04-14-2021, 11:09 PM   #9
Hotcorner
Hotcorner's Avatar
George
Roger.
1969 GMC K25
Old 04-14-2021, 11:09 PM   #10
geezer#99
geezer#99's Avatar
Did you get charts with it to tell you what springs etc to use for desired settings.
You’ll likely want it to be fairly lazy to begin with.
You’ll need to experiment to see what your motor likes.
I’ve got a motors manual here with distributor specs.
Would you have the original distributor with part number.
Old 04-15-2021, 03:56 PM   #11
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
may want to take a look at my thread (page 3), I put my all in at 25K with the springs that are included.
https://67-72chevytrucks.com/vboard/...=818178&page=3
My Truck, from post1
SBC 350 Rebuilt less than 1k on engine at this posting.
TH350 Rebuilt at same time as engine.
307 Gears
Power Brakes and A/C (off during all timing checks)
12° Initial timing
30° ~3500 Max Mechanical (by offsetting light ° button to read 0 on the timing mark)
45° ~3500 Max Vacuum (by offsetting light to read 0 on the timing mark)
17 hg Vacuum @idle
Park/Neutral Idle 650
Tires 275 60 15
60 MPH = ~2500 RPMs
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
